Question about RCA P52926 52" Rear Projection Television
HOW TO CLEAN TV SCREAN
DIRY
Cost repair screen cracked
should have 4 screws on front of tv screan on coners or on back then you should be able to pull front of screan an replace the screan it just plugs in to the mother bord jesus loves u un plug it first
Nov 05, 2013 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Why dosen't the screan turn on when i power on the tv?
Brand and model number are needed (not listed here) to give an answer of any possible reasons.
Apr 11, 2012 | Televison & Video
The motor area is iced up on the machine, and the fan is not blowing cold air?
you will need to clean the coils, with a water hose. make sure you have the power off. This will de-ice the unit. as it is either diry coils or low freon
Sep 12, 2010 | Carrier 38CKC036 Air Conditioner
The console is only two months old and will not load the games
It might be just diry inside try blowing it out or bring it to best buy and they will use a air compressor to clean it out.
Feb 14, 2010 | Sony Playstation 3 (PS3) Console
Where do i find the small signal board in rca d52w23 projection tv ,menu screen pop up sound goes down chainge chenal it self?
Problem is not going to be in your Signal Board SSB,
It is your Front Panel Board/ the board that Has Vol- Vol+ CH- CH+ OFF/ON -POWER/ Either contact switches are Bad OR Very Diry Take Contact Cleaner or you can use rubbing Alcohol to clean contacts.
Jan 18, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Dvd play back has a line from top of screan along
try reinstall converter drivers and software. if persists try to send to repair, maybe a converter board defective.
Jan 16, 2010 | ION Audio VCR 2 PC USB VHS Video to...
What should be used to clean the TV viewing screen
Soft cotton cloth would be fine to clean front screen of TV. Do not use any liquid or detergent in cleaning.
Thanks.
Nov 21, 2009 | Sony KDS-60A3000 60" HDTV
Mitsubishi CS26301 27" TV
Have you tried flipping the pictures so you can troubleshoot it from the larger screen?
Feb 16, 2007 | Mitsubishi WT-42315 42" TV
RCA P52926 52" Rear Projection Television Logo
14 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
