Question about Ariens 34 In. Zoom Series Riding Mower
Blades wont activate
I have an ariens 1742 that i bought not to long ago. first something went wrong with da ignition switch, so i have to start it by touching the neg- with the psoitive+ Now the biggest problem is was cutting my gras in backyard real low and hit something and my blades wont work. when i hit the switch the motor is still spinning also the blet but the blades dont engage. before i go spend money help
Check the timing belt, the belt just above the blade. The blades, if not turned 90 degrees to each other, will clash. Dumb design?; perhaps, but you need some way to overlap when you turn so tightly. I have an early 2000's vintage, but remove the shroud and check the belt. It may be broken. You can actually raise the deck to it's maximum, remove the spark plug for safety sake, and if each blade spins independently of each other and real easy [though one could be jammed somehow], you probably broke the belt. They were just a few bucks shy of $100 a few years ago; I bought two when my last one broke, and luckily I haven't needed the spare. When/if this is the problem, syncronize the blades so that one is 90 degrees to the other. The factory has marks stamped on the pulleys and housing somehow (I'm trying to remember exactly), but in the end lining up those marks achieves that orientation. Hope this helps, Chuck in Cleve Ohio area
Posted on Jul 28, 2009
MY RIDING LAWNMOWER STARTER JUST CLICKS.I BOUGHT A NEW STARTER AND IT DOES THE SAME THING.
didnt specify type of rider but can b 1 of a few different problems-the clicking is the relay to the starter-- 1st check that motor turns if motor bound or seized starter wont turn it over -check that starter gear and flywheel mesh correctly if not might have to shim or adjust ,next check battery {full charge}and connections ,wiring ,and the fuses for corrosion and or damage.check the safety switches next the seat ,brake,and blade on, these switches will not let motor start if damaged ,activated,or bad wire.
Sep 20, 2012 | Ariens Garden
Ariens ezr 1742 mower wont start or turn over.
Check battery voltage.and then check for a blown fuse.
Sep 06, 2011 | Briggs & Stratton Garden
When turning on pto blows the fuse
Look over the entire wiring harness wherever it may be touching metal as it probably is chaffed, simply tape and zip tie it away from the ground source.
Aug 03, 2011 | Ariens Zoom 42 In 165 HP Briggs Stratton...
My 1999 Ariens EZR 1742 will not move. Cranks and
if both belts are present are they both moving? Could be tensioner froze up and it is not applying tension. mine had and i had to remove and free it up.
Sep 26, 2009 | Ariens 34 In. Zoom Series Riding Mower
Looking for manual Arien EZR 1742
Go here:
http://www.ariens.com/corporate/pages/partsradar.aspx
Hope this helps
Jun 10, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens 34 In. Zoom Series Riding Mower Logo
294 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
