Question about Pioneer GM-7200M Car Audio Amplifier
How i have 2 12" 800watt pioneer TS-W301R how/can you wire them to be 2,4or 8ohms. or how does that work.
I think it depends on the speaker itself, it should say on the back the sreaker, most likely on the magnet, what ohm the speaker is.
Posted on Nov 02, 2007
There is a lot of feedback coming from my speakers. it only sounds good if i turn the music very loud but when its low the feedback takes
What kind of head unit do you have. Did you check to make sure you are not getting feedback from a bad speaker output wire. Also ckeck your RCA input cables to
Jun 02, 2010 | Pioneer TS-W301R Car Subwoofer
It makes a ruff noise when u push on it
then you fried it...voice coils are cooked.
Oct 21, 2009 | Pioneer TS-W301R Car Subwoofer
Sony Xplod
If your still getting a green light, it at least sounds like the amplifier portion may still be funcitonal. Perhaps your inputs are blown. If your comfortable with electronics, pop the cover, and try patching a signal directly to the amplifier stage. and of course check your source.
Jun 20, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Blown amp possibly?
i have the same amp with the same problem.....your best bet is to do what i did get a better amp(audio pipe,spx,kicker,punch,etc) do not get pioneer amp or sony anything
Jun 20, 2009 | Kenwood KAC-X501F Car Audio Amplifier
well for step by step instuucion ill tell u what ill do u pay the $10.00 to talk to a tec. me of course and ill explain every thing step by step let me now what ur gonna do
Apr 03, 2008 | Pioneer TS-W301R Car Subwoofer
2 Subs running together
If they have the same impedence (like 4 ohm) then you should be able to run two different model number speakers as if they were the same model number. There might be a slight difference in the way they sound, but I would not expect it to be enough to be noticeable. Good luck.
Mar 27, 2008 | Pioneer TS-W301R Car Subwoofer
you probably have blown speakers or the wires are disconnected
Jan 22, 2008 | Pioneer TS-W301R Car Subwoofer
Need help
It should be better to use the Pioneer GM-7200M Amp with your subs.
For 8 ohm setup hook up this way:
Amp out+ to Sub1 +
Sub1 - to Sub 2 +
Amp out - to Sub2 -
For 2 ohm setup hook up this way:
Amp + to Sub1 +
Sub1 + to Sub2 +
Amp - to Sub1 -
Sub1 - to Sub2 -
Nov 09, 2007 | Kenwood KAC 6201 Car Audio Amplifier
How to
First of all, make sure your amp is bridgeable. There are a few ways to bridge subs. series: hook one wire from the negative on the left amp output (or whichever is labeled on amp for bridged)to left sub negative. left sub positive to right sub negative, then right sub positive to the amp positive output.(like a big loop through both speakers) parallel: both speakers get their own set of wires, both negatives go to the bridge negative terminal, and both positives go to the positive bridge terminal. Series-parallel: A combination of the two. say two speakers in series, and one hooked up alone, but all to the same amp outputs. Bridging your amp/speakers basically lowers the resistance of the circuit and makes more current flow, more power, louder, harder hit. In series, it also makes both speakers do exactly the same thing, instead of "stereo sound" or L/R differences. What you're probably looking to do is Bridge in parallel. That will drop the resistance of the circuit the lowest, allow the amp to put out the most amount of current to the speakers, and allow your bass to hit the hardest. If your amp only has one output, hook up the same way as above. Just see what resistance your amp is stable down to. If down to 1 ohm, no worries. if stable only to 2 or 4 ohms, you may want to bridge in series to be safe. That will cause the resistance to go up, and will not pull as much current through the amp. The whole time, just remember Bridgeing and higher current mean HEAT so watch your amp. I hope this helped.
Oct 31, 2007 | Pioneer TS-W301R Car Subwoofer
Pioneer GM-7200M Car Audio Amplifier Logo
128 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
