Question about Fotodiox Lens Mount Adapter Voigtlander Bessamatic Retina DKL lenses DKL lens to Sony Alpha Camera For Sony A100 A200 A230 A290 A300 A330 A350 A380 A390 A450 A500 A550 A560 A580 A700 A850 A900 SLT-A35 A33 A37 A55 A57 A65 A77
Is an adapter for DLK to the new Alpha 7 available.
I found only adapters for DLK to Sony NEX 7, but they are vignetting.
HOW TO PUT Fotodiox 49mm Filter Thread Macro Reverse Mount Adapter Ring for Sony E-series
The ring threads onto the front of any lens with a 49mm filter thread, just like a filter. The front of the lens then fits onto a camera body, effectively mounting the lens "backwards" or reversed. With most lenses, this allows the lens to focus very close, for close-up or "macro" photography.
Mar 14, 2013 | Fotodiox 49mm Filter Thread Macro Reverse...
Metz flash sony nex camera
Sony NEX 6 has an ATG/Sony's Multi-Interface-Shoe.
Let's hope the Metz 58AF-2 Flash is made for Sony/Minolta, which has an old Minolta's hotshoe.
Contact Sony for the adapter.
Or just buy the Promaster Sony Multi-Ineterface Shoe Adapter, it less than Sony's.
atdlee@netzero.com
Dec 29, 2012 | Metz MZ58321C 58 AF-2 Digital Flash for...
X370
There are adapters available to fit the old Minolta manual-focus lenses on Sony alpha-series dSLRs as well as Sony NEX-series interchangeable lens cameras. The lenses obviously will not autofocus and, depending on the lens and camera body, you may lose some or all exposure metering capability.
Nov 26, 2012 | Konica Minolta Minolta 110 Zoom SLR Mark...
I have 6pcs of lense set of an old asahi pentax camera. The holder is a screw type, so which mordern D-SLR can I use the lense set?
To my knowledge there are no digital SLRs that take the old Pentax screw mount directly. However, there is an adapter available for the Pentax K series (not very surprising). In addition, there are adapters available for the Sony NEX series and the Micro Four-Thirds cameras from Olympus and Panasonic.
Oct 06, 2012 | Photography
Yashica Lens 28 - 80 mm can i fix any digital camara
With the proper adapter, Contax-mount lenses may be used on several different makers' digital cameras, including Canon and Sony.
Oct 01, 2012 | Kyocera Yashica Lens Mc Zoom 28-80mm...
Sony Digital SLR
You should have no problem, if they are maxuum af. The others should work too- I have an Alpha 100. The alpha 100 works great. I used to run my own photography business, and searched around for quite a while before I found the alpha. There is an adapter ring that i bought, that makes it possible for me to use my favorite old pentax screw mount 135mm f1.6, or any other screw mount, on my alpha 100.
The only drawback I found was you cannot use any other flash(at this time) than the onboard one-or the sony only flashes-which are a little pricey. Different size hot shoe is the reason. I haven't found an adapter yet-but I'm sure someone will make one. The alpha doen't have a real time display- or asa of 3200. I'm hopeing for a firmware update/upgrade to correct this. BUT the newer models with a higher than a100 number do have realtime lcd, and do go to asa3200. And they use either sony mem.stick or CF cards happy shooting
Jun 23, 2008 | Cameras
Fotodiox Lens Mount Adapter Voigtlander Bessamatic Retina DKL lenses DKL lens to Sony Alpha Camera For Sony A100 A200 A230 A290 A300 A330 A350 A380 A390 A450 A500 A550 A560 A580 A700 A850 A900 SLT-A35 A33 A37 A55 A57 A65 A77 Logo
44 people viewed this question
Top Fotodiox Photography Experts
pontelemon
pontelemon
Tony
Are you a Fotodiox Photography Expert? Answer questions, earn points and help others
