Question about Swingline DX20-19 Cross-Cut Shredder
Door isn't closing
Door for waste basket isn't closing
Door doesn't shut properly to start dishwasher, have to push door to work but stops if you let go
The machine will not function if the door is not fully closed. The locking/latching mechanism for the door probably needs to be adjusted or replaced if faulty.
Also make sure there is nothing inside the dishwasher that is fouling the door (like a basket rack that is not fully in position) and is not allowing the door to fully shut. Pull the baskets out of the machine and check inside as well.
Dec 20, 2015 | Dishwashers
Filter basket door opens during coffee making.
sounds like there is a bad relay, that is shorting out, and releasing the filter basket accidentally. Also, check to make sure that there is nothing blocking the latch that holds the filter basket in place.
Feb 05, 2008 | Cuisinart Thermal DGB-600 Grinder
Spl-s302d shredder door open
Check to see if there's a little piece that broke off from the door. This would be the "safety interlock switch" or little thingy that pushes down the basket sensor. The basket sensor is located on the bottom front of the shredder. I bent a paper clip to hold down the metal switch (basket sensor) and taped it to the front of the shredder with scotch tape.
Jan 07, 2012 | Staples Office Equipment & Supplies
E1 ERROR
sound s like you have a bad door latch very easy fix and cheep , if you give me all the info on this unit will locate te door latch and tell you .
Dec 16, 2011 | LG LDF6810ST Stainless Steel Built-in...
Why is my frigidaire washer not spinning?
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
Sep 27, 2011 | Washing Machines
My printer says the door is open when it is closed!
the iR1600/2000 will show the message close printer door if the copier paper path door ( on left side of copier, beneath the bypass tray are paper path door in level with paper cass. ) isn't closed well. Open the door and close them with some "gentle" force. It is good idea first to push the paper path guide, before closing the door.
Hope that helps!
Apr 21, 2011 | Canon ImageRunner 1600 Copier
Freezer door does not close
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Mar 30, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Door won't close and door does not lower without dropping out of control.
One or both of the door springs have broken causeing the door to drop.You haven't mention the brand or model so it's hard to help.The door not closeing could be because the door dropped open & is distorted or the door might be hitting a basket if the basket has been put in back to front.
May 30, 2010 | Dishwashers
Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Jan 23, 2009 | Amana ABB1927DE Bottom Freezer...
Door to filter basket won't stay closed
had same problem..i took the basket holder and door off and gave the basket slider a good cleaning along with other internal parts. now works fine
Oct 30, 2008 | Cuisinart DGB-600 Coffee Maker
Swingline DX20-19 Cross-Cut Shredder Logo
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Andrew Taylor
Andrew Taylor
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
