Question about Amcor 3900 GPS Receiver
No sd map card
Need soft wear
Need to know how i update the maps card for it
The latest version of Garmin Express provides the ability to install a map update directly to an SD card.
The SD card installation option will only appear when updating a compatible device that does not have sufficient internal memory for the largest allowable map region. When using the SD card installation option, critical files are loaded to the SD card so it must remain in the device after the update to ensure full functionality. For the largest size SD card a device can use, refer to: What is the largest size Secure Digital (SD) card that an automotive device can accept?
The SD card support during the map update will only function with up-to-date software. It may be necessary to update the device's software with Garmin Express prior to updating the maps. These devices do not support the SD card option:
  • Nissan 700
  • nuvi 295
  • nuvi 300 series
  • nuvi 500 series
  • nuvi 600 series
  • nuvi 800 series
  • nuvi 805 series
  • nuvi 5000
  • StreetPilot series
  • zumo 450
  • zumo 550
  • zumo 665
For devices that do not support using the SD card with the map update application, any maps that do not fit in the internal memory can be installed to the SD card manually, using these instructions:
Try the link.it may help.Under support.
Garmin United States Home
Nov 09, 2015 | GPS
Purchased soft wear upgrade for kenwood DNX8220BT from garmin when it arrived it is an SD card, how do I upload the information to my kenwood navigation system?
Press and hold the eject button for a few seconds. The screen will lower to reveal the SD slot. Put the card in and follow instructions when prompted.
You do not need to leave the card in.
Aug 20, 2013 | Kenwood KVT-512 Car DVD Player
Garmin nuvi 200 SD card
Did you rename the file extensions? On the unit, the map file and map unlock file must be named gmapprom.img and gmapprom.unl
On the SD card they must be named gmapsupp.img and gmapsupp.unl.
Also copy your garmindevice.xml file over to the SD card too.
Feb 26, 2013 | Garmin nuvi 200W GPS Receiver
We downloaded a European map onto the SD card, however, when we look at maps available, the Garmin 260 is not looking at the map on the SD card. How do we tell the device to use the card to search for the...
You need to download the map to your compute rather than the SD card. When downloading the default destination is the satnav but you can change it to your computer. When it's installed to your computer you then click the windows START button and in the list of programs you'll find a GARMIN folder with a program called MAPINSTALL. Connect the satnav to your computer with the SD card in. Run MAPINSTALL and select the SD card as the destination.
You can get more details of how to do it at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
Note maps installed to SD cards do not always work with Garmin Nuvis. To give it every chance of success please follow the instructions at the above link about formatting the SD card.
Jun 14, 2011 | Garmin nuvi 260W GPS Receiver
I have 2010 maps on a SD card for my Nuvi. Does
If you already have a map on your unit, you will have both maps. You may have to enable the map on the SD card. At the main menu, press the wrench symbol, then the map icon and then "map info". You should see all of your maps that are available to your unit. Make sure that the square boxes next to each map are checked. Thats how you turn on/off (selct) each map. If the SD card map isn't working, make sure it has a unlock code assigned to the map or it won't work on your unit. Also, the map file name on an SD card is different than the name on your unit. - Jim
Jul 21, 2010 | Garmin Nuvi 660 GPS Receiver
How to upload maps in garmin 200w from sd card
on menu touch tools, maps, map info, tick the box, you may need unit I.D. and serial number.
Regards.
Mar 21, 2009 | Garmin Nuvi 660 GPS Receiver
NAV CAM 2007 (GPS) NEW MAPS
Here is some other soft for your evesham device: http://www.driveway.com/NF98ogAJWR
http://www.driveway.com/i1EvQzR8FL
http://www.driveway.com/G3N0Y5jQ4s
When you finish the downloads, you need to unzip all the files, then copy the map files into the maps folder. Once this is done, copy the entire thig to the SD card and enjoy!
Dec 20, 2008 | Evesham Nav-Cam 7700 GPS Receiver
Add Europe sd card to Garmin 660
No. When you plug in the SD card, the Nuvi will load the map from your SD card. Once you get to the main menu, select the wrench symbol, then the map symbol and then "map info". You should see both the US and Europe map. Make sure the Europe map is checked. You can uncheck the US map. This is how you switch between maps. The reason why you have to have the extra map on the SD card is because the Nuvi can only have one map on it's internal drive, one at a time.
However, backing up your US map is a good idea.
Good luck,
- Jim
Nov 21, 2008 | Garmin Nuvi 660 GPS Receiver
Map on tomtom go 300
The downloaded maps can be copied direct to the SD card or copied to the SD card via USB lead and PC connected through TomTom Home. Once you have the map on your SD card you will need to activate it with your product code number that you obtained when you purchased the map.
Good luck
Sep 01, 2008 | Tomtom GO 300 GPS Receiver
Amcor 3900 GPS Receiver Logo
20 people viewed this question
Top Amcor GPS Experts
Martin Murray
Donald Ayers-Marsh
Are you an Amcor GPS Expert? Answer questions, earn points and help others
