Question about Consew CES-90A Gravity Feed Steam Iron, Silver Star ES90, 1000W, WaterBottle&Hose, Alum Sole, Iron Rest, Teflon Shoe, Demineralizer, Soft Handle, 5Lbs
Silver Star The water hose was disconnected and put back on to flush it out. The iron started to make the noise. When the steam button is pushed it makes a loud buzzing sound. No water going through the gravity hose, but it sounds like it is trying to pull the water. Solenoid P/N 145100
My Hamilton Beach duration iron produces steam but the burst steam feature doesn’t work
put a solution of 10% vinegar in it and try to flush the system out.... probably that circuit, which pushes a shot of water into the heating coils, is plugged.... if REALLY plugged, you may be looking for a new iron since passage of water with the vinegar is necessary to dissolve the clog to a great degree...
Nov 19, 2017 | Hamilton Beach Irons
Rowenta Iron DG-980 problem
you should have a controll or button on the iron that tells it to release the steam. make sure that the button or controll is not stuck.
Aug 03, 2008 | Rowenta DG-980 Iron
I cannot get my GCSBDS212 steam iron to make steam.
Have a look at the steam holes in the bottom, they should be nice an clean with no blockage. If they are blocked up you will need to remove the calcium buildup inside the iron. Get some LimeAway at HDepot, pour it into the water reservoir, let sit overnight. Next day turn the iron on and try steaming on some old papers covered with an old rag or towel, once it starts working steam for a few minutes, then unplug, drain it, put in clean distilled water and flush it out until the steam comes out clear. Use distilled water not tap water, it has much less mineral content and will be less likely to plug it up. Most pharmacies and Walmart sell distilled water. ! gallon about $1.25.
Feb 05, 2015 | Sunbeam GCSBDS-212 Digital Steam Master...
Rowenta 1500 garmet steamer no longer makes steam
Someone else had this fix and it worked for me: (yay!)
*Remove water tank and collapse the hanger bar.
*Remove two screws at base of hose and work the hose off. It will come out.
*Unplug unit and hold over your kitchen sink with the hose inlet pointing into the sink.
* use your kitchen sink sprayer to forcefully spray water into this hole and it will come back out again releasing the gunk that has been stopping up the unit.
* for good measure, I also used the sink sprayer to flush out the hose.
Put everything back together. And make sure it is dry before you plug it in.
VOILA!!! WORKS GOOD AS NEW. HAPPINESS!
Jan 10, 2014 | Conair Gs4 Iron
"My rowenta DG9540 iron won't stop steaming. It starts as soon as it is switched on regardless whether the steam button is pushed in or not. What might the problem be?"
1) check the ejection button of the stems for particles, has blockage the mecanism by using hard water to due mineral deposit clean it.
2) other wise you must go to some repair shop for fix it.
God bless you
Jul 11, 2012 | Irons
No steam
What you need to do is clean out the steam orifice. (The tiny hole the steam comes out) When water is turned to steam it leaves behind mineral deposits, (Iron, Calcium) Especially if you have "hard" water in your area. Here's what you do. Add some CLR, (Calcium,Lime Remover) to the water you put in the iron, let it sit a while, laying flat, then drain the water out. You want to get the nozzle, to, holding the iron upside down, try to immerse the steam nozzle for a couple of seconds in the CLR or drip some directly on it. You can buy this product in most stores. It works well and fast. Dip your showerhead in it too, you'll be suprised at how it improves water flow. It is safe as long as you follow the instructions.
Apr 06, 2010 | Rowenta DG-920 Iron
Simac Stirelli 9000 steam iron spews rusty steam and smells like burnt apples
Your steam iron has been filled with 'tap' water that may have been contaminated (thus the smell). Rust develops more rapidely in Steam Iron chambers when distilled water is not used: to clean the 'enclosure' of the steam iron from rust and smell, over a sink or outdoor, fill 'cold iron' with a 50/50 water/vinegar and a teaspoon of bicarb, let it stand for about 10 mins, then turn the iron on and let it steam the mixture out while shaking the iron gently (DO NOT BURN YOURSELF! STEAM IS HOTER THAN BOILED WATER!). Refill and Steam flush again with Clean water (distilled preferred). Repeat the steps until the rust has been completely dissolved (check by steam ironing on clean pieces of disposible kitchen paper towel. Use the Power steam or Flush function of the Iron if available. Hope it helps!
Dec 17, 2009 | Irons
Russell Hobbs Steamglide 2200 - no steam
Same with mine! What you have to do is keep taking the water cannister off and pushing back on until its lined up correctley. Also have the whole unit at the same height as the ironing board, that should do it! Can you help with filters? I cant find them anywhere.
Mar 23, 2009 | Irons
Tefal express
The rumbling noise is the steam generator working - make sure the water reservoir is full and press the on button. Inside the machine will be doing its stuff and generating steam - this is the noise that you are hearing and when you press the release switch (normally under the handle of the iron) then the steam will be expelled. The noiose comes on and off as it is making more steam - this is normal. I use ordinary tap water but don't have hard water so have no problems - also make sure you empty out the base occassionally - should be a large pressure screw behind the cable holder - make sure iron is off and cold before doing this and then shake it out and residue bits will come out - then flush out with water. These are brilliant to use and you will wonder how you managed before having this - Happy ironing.
Aug 23, 2008 | Irons
Steam Button
Your iron pump is faulty the high pitched sound is normal.
Rdgs
Alan
Nov 27, 2007 | Rowenta Perfect Iron
Consew CES-90A Gravity Feed Steam Iron, Silver Star ES90, 1000W, WaterBottle&Hose, Alum Sole, Iron Rest, Teflon Shoe, Demineralizer, Soft Handle, 5Lbs Logo
32 people viewed this question
Top Consew Irons Experts
Are you a Consew Iron Expert? Answer questions, earn points and help others
