Question about Sport & Outdoor - Others
Avanti refigerator Model # FF8SSR/ff8WR door trays
Need replacement plastic door tray for Aventi refrigerator Model # FF8SSR/FF*Wr
3 Suggested Answers
EllaWatson25
  • 725 Answers
SOURCE: My Avanti frig has the model# of FF8SSR/FF8WR but
We have parts for Avanti refrigerators. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the information on your parts.
We look forward to working with you.
Posted on Nov 09, 2009
  • 1739 Answers
SOURCE: need plastic tray replacement for model number BRG...
Replacement parts for the Wolfgang Puck BRGG0010 Grill are available here:
http://www.wpcookware.com/products.asp?cat=80
Sorry someone has not responded sooner, but just discovered this site.
Posted on Apr 01, 2011
Crisper glass cover for Avanti fridge
have the local glass shop cut a new one for you
Dec 06, 2015 | Avanti FF8SSR Top Freezer Refrigerator
My Electrolux side-by-side refigerator automatically started dispensing ice cubes in the middle of the night and would not stop until I manually pulled the lever to the stop position. It did this on 2
I have a few ideas for things to try. On the bottom of the ice cube holder I believe there is a spring loaded metal rod that runs from the front of the freezer to a little indentation in the back of the freezer. Inside this indentation there is a small plastic piece that can move up and down to rotate the metal rod. Make sure this metal rod is free to rotate. Sometimes it gets stuck in one position. The position of the plastic piece inside the indent in the rear of the freezer is controlled by a solenoid which is controlled by the buttons on the front of the door for cube or crushed. Close all the doors and push the cube button. Open the freezer door and remove the entire ice cube tray. Reach to the back of the freezer and make sure the little plastic piece inside the indent will move up and down easily. You want it to be in its down position. Re-insert the ice cube tray. The metal rod should fit easily into the indent in the back of the fridge. Now close the door and see if you can get cubes. If this doesn't work I suspect the solenoid that moves the little plastic piece may need to be replaced. I hope this helps you out.
Aug 29, 2012 | Electrolux E23CS78HSS Side by Side...
Hi, i'm looking for a new 'veggie crisper box top shelf' about 13x17, and a 'bottom shelf' for the fridge door, Avanto Fridge Model# FF8SSR/FF8WR Cheers, Christian Lawson 6467846628
IF you go to Appliance Parts Depot and just put your brand along with your model number in the spaces provided then you should be able to order the parts you need your self. That away you can have them shipped to your house and not have to pay all the services fees that companies try to charge you for when they are going to do the same thing. Hope what info that i have gave to you is useful. If not you can email me at douglasappliance@hotmail.com
Jan 19, 2011 | Avanti FF8SSR Top Freezer Refrigerator
Nov 09, 2009 | Avanti FF1101W Top Freezer Refrigerator
The plastic notched tray of the ice cube maker is broken
Those parts are available and require disassembly of the IM to replace.
Eric
Oct 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator with automatic The ice melts and leaks out the door?
Same problem with my unit. The plastic tray seems to warp over time and the water drips out of the tray prior to freezing into the cubes. I was able to purchase a replacement tray online. I also discovered a hidden reset button under the right side where the ice tray motor assembly is located. This button had to be pressed in order to get it to cycle through again after replacing the plastic tray. We'll see if this solves the problem of water spillage all over the interior of the freezer!
Sep 20, 2009 | LG LFX25960ST Stainless Steel French Door...
Coolent leak Avanti model 489
this requires skill in refrigeration depending on size of leak how old is the unit and how large the leak avanti is a great company if less than five years o0ld they will replace unit get in touch with if older than them
Dec 31, 2007 | Refrigerators
Door gasket
Try www.partselect.com, they may have it in stock.
Dec 01, 2006 | Avanti FF8SSR Top Freezer Refrigerator
Sport & Outdoor - Others Logo
19 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
