Question about Symbol LS 4000i Handheld
Scanner enters immediately upon every entry. I need to make multiple entries then enter all at once. I suppose there is the possibility to choose "read&save" or just "read" option but I am not able to enter the settings. Help!
  • 97 Answers
You need to download the pdf manual for this reader whichh you can find in the support page of www.symbol.com.
search within the manual a barcode called set all defaults. this will remove the carriage return after scan.
Posted on Jun 15, 2009
2 factor reset
Try pressing an operation key twice.
For example to multiply any entry by 15, you would enter 15, press the multiplication key twice. Now to calculate the products of you list of entries by 15, you just enter number in your then press =. c.then the second number and =, etc.
Sep 29, 2013 | Casio Office Equipment & Supplies
I have entered several calculations onto my ti-84 plus. I want to know how to scroll up through my previous entries. Thank you.
To get back to the previous entries, you can hit the 2nd button then hit enter. Continue to do this and you will get to the entries before that.
May 02, 2011 | Texas Instruments TI-84 Plus Calculator
How to undo predictive text v3
Welcome to Fixya. If you want to undo the preddictive text just follow the guide below.
1. From any text entry screen (ie. when you are writing a text message), press the top center button, the one above the directional wheel.
2. Press on Entry SetUp
3. Select the Primary Set Up or Secondary Setup by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
ITAP: it's a built-in software which predicts the word you are typing. THIS IS PREDICTIVE TEXT
TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter F press the number 3 button three times.
Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
To change from one mode to the next you can select it by pressing the top center button from a text entry screen, and Press on Entry Mode. Shortcut: you can press the # key on your phone when you are writing a message and you will see abc1 for your primary mode, 123 for numeric; @ for symbols; and abc2 for your secondary mode.
If you have questions please let me know. Thanks for using Fixya.
Apr 04, 2011 | Motorola Mobility RAZR V3
How to turn t9 off on a moto razr??
Selecting a Text Entry Mode
Multiple text entry modes make it easy for you to enter
names, numbers, and messages. The mode you select
remains active until you select another mode.
Press # in a text entry screen to select one of the
following entry modes:
Primary Your primary text entry mode .
Numeric Enter numbers only .
Symbol Enter symbols only .
Secondary Your secondary text entry mode .
Jul 13, 2010 | Motorola Mobility RAZR V3
When i connect to wifi it says authentication failed what does this meean?
Need to enter your WIFI security number entry is usually on the router itself if its common ATT router or the likes the ENTRY for the authentication is printed on router device
SEE WEP setttings WIRELESS ENCRYPTION
should be easy once you enter the security entry
PS your sure its your device you attempting to connecto and not neighbors WIRELESS ROUTER
Jun 11, 2010 | Computers & Internet
I have a hp dv7-1468nr and im getting this problem TVagent.exe the procedure entry point PowerReadAcValue could not be located in the dynamic link library POWRPROF.dll. Can some body please help me solve...
At the start button, choose run. Type MSCONFIG in the text box and hit enter. Choose selectice startup and go to the startup tab. On the startup program list, scroll down until you find an entry for TVagent, uncheck the program so it will not load immediately until it is needed. Click apply and ok to restart the system. You can also disable auto start for other programs as well.
Nov 14, 2009 | HP Pavilion dv9000z Notebook
Cant program frequencies into my uniden bc72xlt scanner
Just to verify you are trying to program frequencies the scanner is able to receive.
This unit is limited to the following freq range.
25.0-27.995
28.0-29.695
29.7-49.995
50.0-54.0 5
108.0-136.9875
137.0-143.995
144.0-147.995
148.0-174.0 5
406.0-419.99375
420.0-449.99375
450.0-469.99375
470.0-512.0 6.25
If the frequencies your are trying to enter or outside these bands you will get a error.
Next Direct Entry Mode Programming
Press Func. + PGM
Press E to enter ch in current location
To change location pres func + Up ^ or down key to choose location then press E
Enter your freq then press E
Hope this helps.
Jul 21, 2009 | Uniden BC72XLT Handheld Scanner
How do you change the text message settings to TAP instead of Abc
How to set up Text Entry Mode?
2. Press on "Entry SetUp"
3. Select the "Primary Set Up" or "Secondary Setup" by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
  • ITAP: it's a built-in software which predicts the word you are typing.
  • TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter "F" press the number 3 button three times.
  • Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
  • Jun 11, 2009 | Motorola Mobility RAZR V3
    You can create a barcode in Code 39 that contains $M. Then scan the Enable Code 39 Full ASCII barcode from the Symbologies section of the LS4000 Series Product Reference Guide (Adobe page 93 of 182). If you are unable to create the barcode Knowledge Article ADC-00266 contains the $M barcode. You may run into problems with your application if it does not see a Control M as an Enter. If this is the case the article contains instructions for addressing this problem as well.
    Jun 09, 2009 | Symbol LS 4000i Handheld
    Symbol LS 4000i Handheld Logo
    290 people viewed this question
    Top Symbol Computers & Internet Experts
    Michael
    Oloyede Monsuru
    Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
