Question about Pyle Padh215 Dual 15" Dj Speaker
Trying to connect pyle PADH215 speakers
Do both speaker connection have to be plugged up.....there are two connection available of the back of one speaker.
  • 3 Answers
Pyle's PADH 215 comes with three different types of connections.... Banana Plug, 1/4" and Speakon. You can use any with this speaker. The reason there are two of the 1/4" connections and Speakon connections is that this offers the ability to daisy chain multiple speakers together as long as you watch your ohm load. And no it doesnt matter which connection you plug it in to
Posted on Oct 10, 2014
What is best way to wire speakers to 70V amplifier
If you are attempting to connect standard 4 ohm or 8 ohm speakers to a 70v amplifier, you will need to purchase "MATCHING TRANSFORMERS" for the speakers. These matching transformers will be available from the manufacturer of the 70v amplifier.
Apr 20, 2015 | Pyle 6.5" Dual In-Ceiling Speaker System
Pyle pcau44 amp
A fuse is blown, check main supply fuse.
Dec 22, 2013 | Pyle Audio Players & Recorders
I am thinking about purchasing the Pyle Home PCB3BK bookshelf speakers. Before I purchase, I need to know how they are connected? I have a JVC CD player that I want to connect the speakers to.
Any search engine will lead you to details about the speakers.
http://www.pyleaudio.com/itemdetail.asp?model=PCB3BK
They're passive mini cube speakers. Unless your unidentified CD player has amplifiers and connections for speakers you are missing the crucial middle piece. What were you going to do about bass?
Aug 11, 2011 | Pyle PCB3BK Speaker
Can I connect Pyle PDIC51RD speakers in series.
Yes, everything can be connected in series. Be sure the positive from one speaker leads to the negative of the next so they will be in phase.
Aug 18, 2010 | Pyle Audio Players & Recorders
We have our power supplies. THe problem is hooking up my speaker to the amp from the radio to the amp to the speakers. What is the connections?
first u need a set of RCA cables,u can pick them up at any car audio shop, plug them into the audio outputs on the back of the radio,run the other to the audio inputs on your amp,from there jus plug the speaker wire into the speaker output on amp then to your speakers.
Jul 18, 2010 | Pyle PLA2200 Car Audio Amplifier
How do you wire them in the box
Placing the speakers next to each other face down, you will notice that the connection points run in sequence +- and +-. Now connect the - (negative) from the one speaker, to the + (positive) of the other speaker. Now connect the open + from the one speaker and the open - from the other speaker to your amp. Your amp should have a bridging indication. On the connection points of the amp, you should see a mark pointing to the first - and the last +. That will be your bridge
Jun 09, 2010 | Pyle (PLBW84) Car Speaker
What size amplifier to I need to operate a Pyle Driver Pro 15 inch subwoofer? It is hooked to a 200 Watt amp and there is no sound coming from the speaker?
You may want to check ALL the connections and make sure you are connected properly. You SHOULD surely hear a lot of sound even with such a small wattage amp. Blown speaker? Blown amp? Have them tested. Also the REM or remote line on the amp is a overlooked wire.
Feb 22, 2010 | Pyle Car Audio & Video
I just installed an Pyle PLD70BT. Can't get any sound from speakers. Even tried an external speaker, still doesn't work. I installed this myself and have installed many stereo systems in the past, never...
May not be a problem with the installation, sometimes ya just get a bad one. If you have hooked it up to power, and ground, and attempted to use a speaker outside of the cars wiring, then odds are you just got a bad radio out of the box.. This sort of thing just happens man, but hey that's what warranties are for right?
Aug 08, 2009 | Car Audio & Video
Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
May 23, 2009 | Pyle PLMRA400 Car Amp
Amp goes into protect mode after volume is turned up
Not enough juice, check the power and ground connections, another possibility is to have dc in the input, try to use in line filter available from radio shack to cut the dc, also test the with one speaker at the time, you could have a bad speaker (shorted) too.
Apr 08, 2009 | Pyle PLA4240 Car Audio Amplifier
Pyle Padh215 Dual 15" Dj Speaker Logo
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
