Question about SATO Office Equipment & Supplies
Adjust printhead temperature
How to adjust printhead temperature?
How do I fix error B200
"The error code is standard for many of the late model MPxxx printers. The B200 error is "Printhead Temperature exceeded", What this means that while you were printing some document, either one or more of the printhead ink wells ran out of ink and the printing continued. Printhing without ink in the wells will OVERHEAT THE PRINTHEAD NOZZLES and can potentially burn the out. The printer has a built in temperature sensor to detect the ambient temperature and to monitor the temperature of the head. This data is always collected and monitored and saved in the EEprom data and the Service Test print data.
If the error will not go away once you have unplugged the priner for at least 5 minutes, then there is the possibility that you have already burnt out the head. Remove the printhead and use a 5x magnification glass to look VERY CLOSE at all of the nozzles to see if you can detect any possible burnt out nozzle.
It many come down to need a new printhead.
HERE IS THE LINK, IF YOU HAVE PROBLEMS.
http://www.fixyourownprinter.com/forums/laser/13864"
Dec 01, 2014 | Canon PIXMA MP280 Photo Inkjet All-in-One...
How do i fix canon mp280 for error b200
Dec 01, 2014 | Canon MP280 All-In-One InkJet Printer
Why display error printer head too hot
According to the user manual, when this error occurs, The printer stops; the ERROR light flashes.
Caution •
The printhead may be hot enough to cause severe
burns. Allow the printhead to cool.
The printhead is over temperature. Allow the printer to cool. Printing
automatically resumes when the
printhead elements cool to an
acceptable operating temperature.
Jul 03, 2014 | Zebra 110Xi4 RFID Label Printer Transfer...
ERROR CODE 13,266.44
13,266.44 The Printhead reservoir heater took too long to reach setpoint temp.
Initial Actions:
Check that all system grounds are secured
Check the ambient room temperature
Check the fan operation and vents
If the problem persists, and you are trained on servicing this printer, then you can test the Printhead Reservoir temperature in the Service Diagnostics Reservoir Temperature test. It is either the Printhead itself or the wiring from the Printhead to its Electronics Module. This can be a very costly repair both in parts and labor.
Jun 07, 2014 | Xerox Phaser® 8550, 8560, 8560MFP Extended...
Does anyone know how to rectify the TEC B-SX4 head temperature error? it's the correct version printhead for the model of MLB and the correct firmware, but problem still exists.
This excess temperature may be caused by a temperture detector.
Ther are two detectors on a Toshiba Tec Printer.
- On the print head.
- In the top part of the label sensor mecanism.
You cna check if they are working when going in the adjust set parameter setting.
You can read Head temp and air temp
If one of them is not working you will not be able to adjust the temperature. Worst you'll have the message Head excess temperature message.
Oct 23, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
Change head temperature paxar 9820
There is a small shaft on the back panel of the printer, below the red/white dip switch settings. This shaft sas a slot in it. Facing the rear of the printer, turn this shaft clockwise to increase contrast.
Press PAUSE and FEED buttons on front panel AT SAME TIME to print two label test labels. One of these labels will tell you your contrast setting. I wouldn't adjust the contrast any higher than about 75 (about half way) or you're in danger of prematurely blowing your printhead. Printheads are expensive...
Oct 07, 2011 | Paxar Monarch 9825 Thermal Label Printer
Bar code printed on sato m5900 Rve printer will not scan. Same bar code printed on HP laser WILL scan. Font used is ID Automation 39 - prints at 6 pitch
Are you printing in thermal transfer mode or on thermal direct stock? Sounds like your image is not black enough for your scanner. Things to check: adjust printhead temperature, change ribbon stock, change thermal-direct stock, adjust scanner's sensitivity.
Jul 18, 2011 | SATO M5900RVE Printer
Does not print error b200
Helo, found on web. Good Luck :0)
Nov 07, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Datacard SP35 - High Temperature
If you want to "control" the temperatur on the printhead , you first of all need to install Diagnostic program for your printer.
On the menu go to values.
Find Ymck power, which probably is on 0. and try to adjust to MAX 50 or -50.
Push the : Save current values to power on , button.
The passaword is 42360..
Dec 03, 2008 | Datacard SP35 Printer
35 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
pkwc
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
