Question about Design Within Reach Sapien Bookcase - Short
Shelf size not deep enough to support oversize books. Even large hardcover books bend over time.
Need to reduce the size of programs displaying
Do you have a small handgun? Fire away and you will no longer see oversized display items.
Mar 18, 2016 | Televison & Video
What is the sizes on new & worn rings on Bajaj RE205 Piston
the size of the ring will be determined by the bore size
so if it is a 3"(75mm) bore the ring will be that size if placed in the bore separate to the piston and pushed square and to the bottom of the bore the ring gap will denote if standard , worn or oversize to standard
new rings in new bores will have a ring gap of around .010"
worn rings will have a larger gap up to .040" and will have sharp edges where the ring lands wear the rings
over size rings in standard bore probably won't even fit in the bore to start with
ring sets are bought in standard size , .010" over size,.020" oversize,.030" oversize,.040" oversize with the oversize equalling the final hone of a machine bore
so if the machine shop bores the cylinder out to .020" oversize then you need .020" oversize rings to maintain the correct ring gap
from experience I have found that if I follow that rule , on measuring the ring gap at the bottom of the bore the ring gap is about .015" or half worn out
I counter this by getting the next size ring .030" and filing the ends of the rings at the gap to obtain the .010" gap This has produced better longer lasting repairs
Jul 27, 2015 | Bajaj Motorcycles
What is a binding machine?
"A binding machine binds a stack of papers into a book or booklet. There are many kinds of binding machines, from those that use a spiral binding like a notebook to those that use glue like a hardcover book" (wiki.answers.com)
Oct 03, 2013 | Office Equipment & Supplies
How to change the oil pressure switch
Buy a new switch, If you have a large enough Wrench, then put it on to get the right size, if not... Then use a Socket (DEEP) or a pair of Vise Grips..
Remove and Replace. It just screws in
Apr 10, 2013 | 1996 Oldsmobile Bravada
What deep socket size do you need to remove oil pressure sensor on a 2005 dodge neon sxt?
Typically they are 1 1/16" but a regular deep well socket usually doesn't have a large enough opening on the inside to clear the plastic part of the sensor. They make sockets in this size just for oil pressure switches. I went the cheap route and bought a craftsman socket then removed the extra part of the socket on the inside with a die grinder. Took about ten minutes to do.
Oct 03, 2011 | 2005 Dodge Neon
What to do if water pump bolt breaks,97 mercury mountaineer
You have to drill the remainder of the bolt out of the hole. Start by taking a center punch and punch the dead center of the piece stuck in the hole, then take a small drill bit and get to work on the punch hole. Use a little wd40 on the bit to keep it from overheating and go about half speed on the drill (time consuming prosses). After you drilled deep enough grab the next size bit and continue to do this until you can fit a good size extracter in the hole to pull it out. If you do not have an extracter then continue to drill untill the bolt is completly out then retap new treads and find an oversized bolt.
Sep 14, 2011 | 1997 Mercury Mountaineer
My cylinder got gouged by the piston. Can I bore
It depends on how deep the gouge is. Having it bored and a new oversized piston may set you back more than a new stock piston and cylinder.
Oct 26, 2009 | 2005 Honda CRF 250 R
Screen is size is to large can't find minimize box
Not enough information. What window are you talking about? Press the "windows" button and the "M" key to minimize everything. Right mouse click on the center of the screen and select "properties". You can then change your resolution so that things fit properly.
Jan 05, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Cant download large files to my book
The controller board in Mybook might not support files over 4 gb. Check with the manufacturer if there are any new drivers for you product to solve your dilema. You could also just buy a cheap external case for the drive in the mybook and swap it out. None of the new cases have these limitations and you can get them online for less than 20 bucks. I like MAD Dog cases myself. I hope this helps you.
George
Jul 15, 2008 | Western Digital 500GB My Book World...
Try converting from FAT32 to NTFS. That should take care of the problem. Check out http://support.microsoft.com/kb/314097/EN-US/ for the XP instructions.
Oct 23, 2007 | Western Digital My Book Essential Edition...
Design Within Reach Sapien Bookcase - Short Logo
Top Design Within Reach Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Design Within Reach Furniture Expert? Answer questions, earn points and help others
