Question about Lexmark X364dn
Error code 929.02
Toner sensor low
WorkCentre 7245. What does error code 009-380 indicate?
That error indicates the yellow atc sensor detects a low toner concentration. Try clean atc sensor and reset value to 0.
Nov 06, 2015 | Xerox Office Equipment & Supplies
Bizhub 283 error code c2557
Abnormally low toner detected TCR sensor.
Problem with the developer, toner sensor, or if a PM was done and the counters were not cleared property. Open and close front door to reset. If error returns, check developer unit.
Apr 26, 2014 | Office Equipment & Supplies
No fonctions
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
Feb 24, 2014 | Sharp SF-2025/2030 Copier Toner Black...
Error code 2557
C2557: Abnormally low toner density detected black TCR sensor.
Detailed Error code explained below.
Possiable solutions.
* Open and close the front toner door.
* Restart the machine by turning off the LCD screen power switch, then by the main body switch located behind the access panel above tray 1 indicator light.
* Call Konica to get a tech out.
C2557 Abnormally low toner
TCR sensor
• When sampling data is determined in TC
ratio calculation control, TCR sensor output
is higher than a predetermined value for a
predetermined number of times in a row
even though there is toner in the sub hopper.
Feb 19, 2014 | Konica Minolta Bizhub C550
F2 error
Well F2 error codeis on a variety of Sharp copiers, the F2 error code would normally be accompanied by a sub code that indicates the fault, You may please check out the following -
You may post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
Sep 10, 2010 | Sharp AR-5316 Advanced Digital Imager...
Code error E000024-0001 in canon model ir-2830.pls tell how to rectify the problem
error from developing unit.try to blow all the toner and reinstall new toner .clean the p/j linking dp unit .check for toner intake .if the toner is low and toner motor does not operate or there is toner dump in dispensing
Sep 07, 2010 | Office Equipment & Supplies
Solution for SHARP AR 5127 error U2-40 call for service
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
Feb 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
Minolta bizhub how to reset error code 2557
You will most likely need a service technician. This error code indicates an ATDC (Automatic Toner Density Control) sensor failure. This means that the machine is seeing either an undertoned (not enough toner) or an overtoned (too much toner) condition within the imaging unit. This usually requires possible sensor replacement, or most likely a starter (developer) change and recalibration.
This can be caused if you have run the machine low on toner or possible used the wrong toner in the machine.
You can reset by opening then closing the front door on the machine or turning the machine off then on again but most likely the code will return.
Good Luck
Dec 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Xerox Model 2515 Will not clear Toner Empty Stop Error
I had one today with a toner low light with new toner installed. Turns out they broke the green cartridge retainer clip.
The toner sensor pn# 130K45680 btw.
let us know if it was the sensor.
Aug 03, 2009 | Xerox Office Equipment & Supplies
J1 error code
J1 is detecting either a low or out of toner condition.
Maybe just need to have the cartridge shook, replaced or it could lastly need the toner sensor replaced.
Mar 07, 2008 | Xerox 3001 Copier
Lexmark X364dn Logo
87 people viewed this question
Top Lexmark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Robert Monigold
Robert Monigold
micky dee
Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
