Question about Bosch 24 in. SHX46A05UC Built-In Dishwasher
DISHWASHER IS DEAD
NO LIGHTS NOTHING.
Dishwasher won't start.
If it won't complete diagnostics, replace the main control Help Me Find My Model Number RepairClinic com
Jul 26, 2016 | KitchenAid Dishwashers
ADG 7540 POWER ON NOTHINGS HAPPENING Lights all on nothing moving
most like the door switch is faulty or the door springs are loose and does not hold the door tight causing the door switch to fail. Try pressing the door with hand and operate on at the same time.
Dec 10, 2012 | Whirlpool 24 in. ADG7540 Built-in...
Kenmore 66517514202 dishwasher has no power dead no lights nothing
Does the wiring come up through the door at the bottom to the control panel? Check for a broken wire
May 21, 2012 | Kenmore Dishwashers
No lights on whirlpool quiet partner ii -- is it dead?
The main board sends power to the display lights. Check with a multimeter for voltage coming out of the main board to the display board. If no voltage the main board is bad or the fuse is bad.
Nov 25, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore Dishwasher 665.15762000 stopped dead, will not start, no lights?
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 28, 2011 | Kenmore 24 in. 15933 Built-in Dishwasher
Why is it dead?
Check power at the source; there could be a tripped breaker. If power is getting to your dishwasher, there may have been sudden failure of a part, such as the heater.
Apr 14, 2010 | GE Dishwashers
Briva In Sink Dishwasher Stopped Working!
With a dead unit like that it could be pretty indepth but eliminate the easier things. The unit sould have a fuse that can be checked.
Jun 05, 2007 | KitchenAid 40 in. Briva KIDS42EPSS...
Dishwashers Logo
32 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
