Mercedes fault code h1
Ulei
What the code h1 means samsung washing machine
H1 on a samsung washer is a heating problem.
You need to check the heater and the control unit and find the fault form there.
If you have a multimeter you can test the heater as it should read about 28 ohms. If faulty then the heater will need to be replaced to cure this.
Check it out and see what you find but the H1 error code is a heating problem.
~~~via just answers
Feb 14, 2016 | Samsung Washing Machines
What does code h1 indicate?
H1 ie a HEATER fault, which usually occurs after the fill and just as the machine is about to start heating the water, when your machine detects that the heater has gone "open circuit" . This is probably a failed heating element(There is a break in the wire inside the element) . I can't be specific because you don't mention the model number, but washing machine heater elements are usually available on eBay or from your local white goods supplier fairly cheaply (You will need a model umber to make sure you get the correct one). Replacement is not too difficuly. There are many many YouTube videos available with instructions
Sep 25, 2015 | Samsung Washing Machines
H 1 flashing Frigidaire side by side
I appreciate your post, Sharon!
From the information you have provided your Frigidaire side by side refrigerator is displaying an "H1" error code. I was unable to locate that error code but I did find the error code "HI" which stands for high temperature inside of your freezer compartment. Check your freezer is it still cooling? If so it may just be a miscommunication within your refrigerator and you can clear that by disconnecting the power cord for roughly ten minutes. If you continue to experience an issue I would recommend having a professional technician out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Best of luck! -Matt
Mar 24, 2015 | Frigidaire Refrigerators
Ideal icons boiler fault code h1
ideal icos
H1 fault
FLOW THERMISTOR
part number 170917
check wiring to flow thermistor NOT loose first
Sep 16, 2013 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Lennox 8 series ms8-z0-2ap3a error code H1, defrost operation
h1: defrosting /normal operation/ normal defrost operation.
see more: Air Conditioning Fault Codes
Jan 16, 2013 | Lennox Heating & Cooling
Mi lavadora samsumg marca error H1 .. en el manual no pone significado ,,que hagooooo,,,
hello Diade !
look here : http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3369-generic-daewoo-washing-machine-and-washer-dryer-fault-codes.html
Nov 19, 2012 | Televison & Video
Samsung washing machine error h1
hi !
Aug 13, 2012 | Washing Machines
Fault code 2251
esp code usually means brakes could be a faulty sensor or pads need changing good luck
Jan 12, 2012 | Mercedes-Benz Mercedes Benz A Class Maisto...
A/c climate control
DISCONNECT THE BATTERY FOR 10 MINUTES OR SO, THIS WILL ERASE THE CODES, BE ADVISED IF THE PROBLEM THAT SET THE CODES IS UN-REPAIRED WILL BE SET AGAIN.
PLEASE RATE THIS SOLUTION, THANKS .
Oct 22, 2008 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
