Question about Whirlpool Mh1170xss-0 Microwave Ovens
Not working There is no light nor clock. Working
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
Lights on but keypad not working
The lights in the oven are seperate from the one in the control panel/clock. IF the control panel and clock dont work then it is not something that is easy to fix. Could be the fuse of the controller board.
Sep 30, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE JES831WB 001 microwave that I'd love to fix. The light, clock & timer are working, but that's all - no fan nor heating. Any suggestions?
The door switches are often a problem, one or two are probably defective which would cause the symptoms that you are describing.
Apr 05, 2012 | Microwave Ovens
I have maytag advance cooking system(electric) and the oven will not work.The timer to set the oven and the time is not lighting up but the stove is working.any sugestion
try resetting the clock. If it is digital, push the clock button and then the number buttons untill you have the proper time displayed...then push the clock button again. If your clock and timer are manual, try pushing in the clock lever and turning it 1/4 turn. If this works it would indicate that your timer has a start and finish time and that the oven is not working because the clock has rotated around to the finish time.
Sep 09, 2011 | Microwave Ovens
Microwave stop working
my microwave oven just stopped heating giving me a f9 error .lights are on clock is working and the panel is ok.
Jun 15, 2010 | GE Profile Spacemaker Over-the-Range...
No heat
heating element stopped working
easiest thing is to get a new microwave
Dec 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Clock is flashing - no other buttons will work
hi
it sound like the keypad has died does happan on sharps does the light come on when you open the door ,onother problem that can happen is if one of the microswitches is sticking from storage ,if they are not working in sync then the keypad won't work
cheers grant
Oct 22, 2008 | Sharp Microwave Ovens
Will not restart or respond to reset clocks or lights wont work nothing works what should we do
Don't do nothing at all??
If nothing works or no lights come on, try to change the outlet if not working replace the fuse of the MW
May 11, 2008 | Microwave Ovens
Whirlpool Mh1170xss-0 Microwave Ovens Logo
13 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
