Question about Sta Rite Pool & Spa
Pressure switch burns up
Pressure switch keeps burning up
    Top Expert:
  • Sta Rite Master
  • 8,502 Answers
Check for loose wires
Posted on May 25, 2016
My mercedes slk automatic does not seam to disengage when i stop keeps pulling
Have the codes read. Could be with the TCC solenoid or pressure switch to the TCC keeping the converter partially engaged. If it where fully engage the car would die. Check this soon as it will burn something up in the transmission..IE.. Clutches and more.
Jul 30, 2016 | Cars & Trucks
I want to know what to do. The oil light keeps on burning on the dash. the oil level is correct and oil pressure is ok.
IF the pressure is good (how did you check it?), then most likely it's the sending unit went bad, as happens at times.
Nov 02, 2013 | 2006 Cpi Supercross SX
Jandy LX400P-L Heater
ur blower may not be producing enough air flow to constantly keep the air switch closed
May 07, 2013 | Jandy Pool & Spa
Pressure switch 120 volt compressor how to bypass pressure switch
Un-plug the compressor and remove the cover to the pressure switch. Inspect wire connections for burned /discolored wires. If not burned, look for button to manually trip switch (switch has on /off lever, place in on position). Test with ohm meter for continuity. Switch is normally closed and contacts are usually visable to evaluate condition. Some compressors use a very small sealed pressure switch that is also normally closed.
Oct 25, 2012 | Campbell Hausfeld 5HP 20 Gallon Single...
Driver's window keeps burning out. Window goes down fine, goes up easy with new switch, but in a few weeks the uo portion of the switch burns out
You could have a short in your wires or if your seals are bad on your windows could be leting moisture get to your switch and causing it to burn out
Sep 29, 2012 | Cars & Trucks
Problems headlight lincoln contiental mark 5
Check or replace your Dimmer Switch. I had one go bad and it kept burning up the switch.
Jan 25, 2012 | Lincoln Mark V Cars & Trucks
When I put paper clip ac works but Otherwise it ...
The low pressure switch on the a/c line is at fault or you have to little freon in system to make the pressure switch work. The low pressure switch is put in the a/c line to keep you from burning up the a/c compressor. Anytime the freon fall below a certain level (pressure) then the switch will cut out to keep anything from burning up. Hope this will help you.
May 20, 2010 | Cars & Trucks
My well keeps breaking the circuit breaker, I have had three pressure switchs put in they last for a few weeks and then they start tripping. Last time if I moved the wires at the pressure switch the pump...
The motor for your well pump is going bad and it is pulling too much current on the start up ...this is burning up the pressure switches and is tripping your breaker..
It may be cheaper to replace the whole pump then to just replace the motor...
heatman101
Apr 22, 2010 | Flotec Corrosion Resistant Shallow Well...
Pool & Spa Logo
55 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
