Question about Konica Minolta Office Equipment & Supplies
8t limp mode solutions
Coad c03ff
  • Konica Minolta Master
  • 6,161 Answers
What model number
Posted on Jan 14, 2016
DIALTA DI 183. What does code CO3FF indicate?
Minolta di183 C03FF
minolta di183 C03FF Go to Adjust Mode 11, change the setting from 0 to 1.
Sep 08, 2015 | Minolta Office Equipment & Supplies
Me problem is code c03ff
Hello by mistake you have changed the copier model ..
hi...this error code appears after you clear the data in service mode...so you have to enter sevice mode
Utility+stop+0+0+stop+0+1....enter to ADJUST &specify the speed model from the table find 21-18-16
select the model you have
Feb 27, 2014 | Konica Minolta Office Equipment & Supplies
Konica Minolta bizhub 215 Printer error C3451& C03FF
For the C3451 Code replace the Fuser
For the C03FF there machine thinks it one model type the circuit board are set to a different model Change setting in Service mode under adjust to proper model.
Apr 01, 2013 | Konica Minolta bizhub Office Equipment &...
What is code c03ff for konica minolts bizhub 215
Model Setting - go to service mode press ( utility stop 00 stop 01 and go to adjust select model press off and on
Jan 24, 2013 | Konica Minolta Office Equipment & Supplies
Trans stuck in limp mode i'm getting a p1751 code
P 1751 Shift Solenoid" A" performance. The solenoid is part of the transmission valve body and yes if this solenoid fails you will get limp mode.The only solution is a new solenoid may be even the wires to it or even the transmission module
Feb 26, 2012 | Cars & Trucks
1 month ago my x type went into limp mode. Mechanic had it for three days and could find nothing wrong. Then today it went into limp mode four times. No warning lights on dash
The only time a vehicle goes into limp mode is when there is ****** problems, so I would take it to the ****** shop for code retrivel and if I am not wrong there might be problem with the Input/Output speed sensors BUT do have it checked first.
Sep 16, 2011 | Jaguar X-Type Cars & Trucks
2008 HD STREET GLIDE KEEPS GOING INTO LIMP MODE HAVE 8500MI HARLYSAID THEY FIXEDTHE FLYWIRE AND THAT WAS THE PROBLEM 15MI DOWN ROAD SAME THING ,THEY CLEARED COADS 15-20 ENGINLIGHT COMES ON THEN BACK TO...
Id try another dealer....good luck or change out the part in hand grip.. also where these wires plug into harness clean conections then use a moisture sealent . hd has had problems inthis area w/ what is called fretting..
Feb 10, 2011 | 2008 Harley Davidson FLHX Street Glide
C03ff code coming in bizhub-211 ,even after set the correct the model in service mode
C-03FF after connecting the key counter.
Description:
C-03FF.
Solution:
CAUSE: Incorrect setting.
SOLUTION: To correct the C-03FF, perform the following:
1. Enter the Service mode.
2. Enter the Adjust mode.
3. Select machine setting.
4. Set the machine setting to 21 PPM.
Apr 03, 2010 | Office Equipment & Supplies
C03ff
CAUSE: Incorrect setting. This can occur after a memory clear is performed.
SOLUTION: To correct the C-03FF code, set the machine to the correct speed by performing the following:
1. Enter the service mode.
2. Select 2 for the adjust mode.
3. Go to setting AD11.
4. Set AD11 to "1" for 18 cpm.
5. Exit the service mode.
to access the service mode .enter UTILITY KEY STOP 0 0 STOP 0 1 .GOOD LUCK
Jul 18, 2009 | Minolta DiALTA Di183 Copier
C03FF Minolta bizhub 210
C03FF, is the improper or unmatched model setting code. go to "service mode" In service mode please select "ADJUST"
in "ADJUST" please select "Model Setting" in "Model Setting" select the cpm, (Copy speed) of your machine, for example if you have bizhub 210, then select "21" from the list. if you have bizhub 163 then select "16" from the list and press "yes" button. code will remove.
Jan 29, 2009 | Konica Minolta DiALTA Di183F Copier
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
