Question about Insignia NS-L32Q-10A 32 in. HD-Ready LCD TV
Debug appears on screen all the time
Why is this happening? is it the tv or my uverse connection?
My Tv is Craig model CLC503. My AT&T Uverse remote will not power on or off the TV.
Access the help section of the menu on your uverse connected TV. Select the option "Remote Control Setup". Select your style of remote and select the type of device that you want to program your remote to and then just simply follow the instructions provided on-screen.
Mar 17, 2014 | AT&T UVerse
Word "debug" on my vizio tv screen
Sounds like firmware corrupted. A firmware update might be necessary. Contract the authorized service center for Vizio.
Gopakumar Gopalan Google
Mar 10, 2014 | Televison & Video
My motorola set top box is in debug mode
Hold the power button to give it a fresh restart and let it do it's thing. If it takes more than 10 mins., call 8002882020 and have them run tests on it. You might have to get a new one (it's free to swap)
Mar 03, 2014 | AT&T UVerse
Word Debug showing on Screen
We regret to inform you Panasonic TV's do not use any errors similar to Debug. We recommend you contact the source provider that the TV is connected to.
Mar 03, 2014 | Panasonic TC-P50S30 VIERA 50 Class 49.9...
I need the AT&T UVerse remote code for my samsung blue-ray player BD-D5700
Feb 01, 2014 | AT&T UVerse
LG 42in LCD. All of sudden this weekend the sound goes off. I could have swore I saw the mute signal pop up then right back off the screen. My tv is connected to Uverse, a soundbar and an Xbox 360 and...
If it works with the 360 and speakers are on---disconnect power from the TV and the box for the uverse and after a wait power them back--its possible a glitch from box if used caused this.
Also if box has audio/video outputs connect from them to a rear input on the set to see what happens.
Nov 05, 2012 | LG 42LC2D 42 in. LCD HDTV
I can find codes for a black standard uverse remote which is 1040. But I cant find a code for silver standard uverse remote. Uverse says to talk to DYNEX. Can you help?
i currently use uverse and none of there remotes work for dynex tv's i suggest buying the logitec harmony 520 or 420 or above remote from amazon read the reviews there around 40 dollars and lets you control everything and they connect to you pc you just plug in you model number and the remote learns all the commands as well as lets you set up activities that will allow you to control multiple devices without having to switch between hitting the tv button, home theater button, uverse box etc.
hope this helps.
Mar 14, 2011 | Televison & Video
Just brought a new Sharp Aquos LC-40LE810UN. Every time I turn on the TV, using either HDMI or component cables, the input screen ALWAYS cycles between 480p and 1080i trying to find a "signal"...
This tv the tv Tuner signal board have intermittent interlacing scanning freqencies problem.Tv is new,u just bought this tv wright,return it get another one for the replacement.
Dec 11, 2010 | Sharp Televison & Video
DeBug appears whenever
what IE are you using?
the debug will appear when you using IE6. the reason is that most of th web site have activex. IE6 can't handle it. you need to install IE7 sp1.
Mar 27, 2009 | Microsoft Windows 2000 for PC
Connection
This can be done. The uverse cables have to be hooked through the vcr, which must be left on all the time. Then the VCR to the uverse receiver. It's basically the same hookup as through a cable box.
Sep 01, 2008 | Toshiba W627 VCR
Insignia NS-L32Q-10A 32 in. HD-Ready LCD TV Logo
24 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
