Question about Shure Scm268 4 Ch Microphone Mixer with Phantom Microphone
Shure Scm268 over modulating
Anything louder than -21 dB and it over modulates. I had this problem before and replaced the mixer.
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
I'd suggest contact Shure for assistance in troubleshooting or getting it repaired.
Posted on Jun 24, 2014
2 Suggested Answers
  • 4234 Answers
SOURCE: micro shure ams26
Unfortunately there is nothing that you can do. These mics are designed for user ONLY with Shure products as shown in the exceprt from the user manual below:
AMS microphones do not use standard phantom power. Only
use the 7 Vdc bias power provided by and AMS mixer. Connecting
the microphone to any other mixer or power source may
damage the microphone.
Posted on Dec 23, 2008
Sm58 for speeches
Turn up the mixer, then it will be louder.
Apr 26, 2013 | Shure LX-2 With SM58 Professional...
How to express a loss as a gain in dB?
Decibel is what sound is rated in.
The sound level is expressed as a line.
0 in the middle.
Negative values are to the left, Positive values to the right.
Less DB rating to the Left, more DB to the Right.
Anything above the 0 is louder. 1, 2, 3, 4, 5, 6, etc.
Anything below the 0 is not as loud, -1, -2, -3, -4, -5, -6, etc.
It would be correct to state a 6 DB loss as -6DB.
Regards,
joecoolvette
http://en.wikipedia.org/wiki/Decibel
May 17, 2012 | Computers & Internet
After we switch from the auto to another manual mixing board the volume on one of the mics is decreased dramatically. all other mics are not effected. both boards are linked and we have a toggle switch to...
Check the cables. If one lead of an XLR-XLR cable is shorted to ground, 6 DB gain is lost. You haven't really supplied enough information regarding cables and model of the manual mixer for us to help much. Do check that ALL of your audio interconnections are BALANCED lines either XLR to XLR or TRS cables. Grounding one side of a balanced line reduces gain 6 DB. Try swapping mic cables and channels to test where the problem is in the system.
Aug 31, 2011 | Shure Distribution Shure SCM810 8 Channel...
Mixer is introducing crackling sound intermittently to the process
Isolate one channel at a time to see if a particular channel is the problem. Make sure ALL interconnected equipment is powered from the SAME receptacle or power conditioner. A remote amplifier MUST be powered from the same source as the mixer, even if it requires a separate run to power it. Make sure all cables are BALANCED, either XLR or TRS cables. Sometimes a cable can have a broken wire or shield and cause this.
Jun 16, 2011 | Shure Distribution Shure SCM268 4 Channel...
I have a Shure mic hooked up to my emachines T3092 through a Behringer mixing board. The board works fine, but I am getting over modulated scratchy voice when I record to cool edit pro. Tried every...
Which particular mic?
Go through the signal chain. Mic to mixer to pc.
All the level changes are suspect, what busses are you using...
e.g.
mic to channel 1 on mixer.
trim on mixer 1
fader on mixer 1
L/R balance
fader on L/R
which output from mixer are you using
Then the windows mixer (start/run "sndvol32.exe")
adjust the volume, WAVE, mic, etc.
My first instinct is the windows mic level.
Dec 03, 2010 | E-Machines T3092 PC Desktop
I am replacing capacitors on the 52" Samsung LN52A650 HDTC LCD. What should I know to complete this process. Thanks, Tom
Make shure the Voltage Ref. give the right riding On The IF/RF Modulator... Cause Capacitor fail to response, Choke filter, Possibility bad noise make your Color mixer fail to respond
Sep 21, 2010 | Samsung Touch of Color LN52A650 52 in. LCD...
I need to program my transmitter to work with the db dlm-3 for a 2003 suburban. The transmitter is also operating a silencer alarm model 6918a. It is a silencer 4 button transmitter
the db-dlm3 is a module to make your door locks work with any alarm. the transmitter is not programed to the module but to the alarm if you need to program transmitter turn key to on position push valet 5 times then hit lock button on remote
Dec 10, 2009 | DB-DLM-3 Door Lock Module
Wireless Microphone low volume
The PGX1 bodypack has a switch on the side to set the gain. Make certain that switch is in the "mic" position. Otherwise, simply turn up the volume on your mixer.
Jan 24, 2009 | Portacom Porta-Com COM-60FC 6 Headset...
Micro shure ams26
Dec 23, 2008 | Shure AMS26 Professional Microphone
Shure Scm268 4 Ch Microphone Mixer with Phantom Microphone Logo
53 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
