Question about Autel Maxiscan Ms309 Obdii Code Reader Obd2 Eobd2 Obdii Eobdii
OBD2 Scanner problem
Plug it in, lights up, no wording
I have a 05 Scion tc and my check engine light came on, so i pluged in the OBD2 scanner but it is not reading anything
Reguarding your 05 Scion tc with 'check engine' light on......You plugged in an OBD2 scanner,or a code reader ??
Feb 03, 2015 | 2007 Scion tC
What does "engine system faulty" warning light mean
If you want to debug the problem yourself, the first thing to do is to buy a engine OBD2 scanner. When the code show up, you may see what is the problem using the OBD scanner and your cell phone, with the proper app (like Torque for Android).
Remember to check if you are buying a bluetooth OBD2 scanner, and your phone have bluetooth as well.
One more thing, the OBD2 connector on the Peugeot 307 is right behind the ashtray, remove it to have access to the OBD2 connector.
The most probable cause is the fuel intake, may be the fuel, a filter or even the electric gas pump. Just a OBD2 scanner will tell you accurately the cause of the problem.
Best Regards
May 07, 2013 | 2006 Peugeot 307 2.0
What code scanner is needed for a 1994 olds cutlass supreme 3.1?
1994-1995 was a transition year for car makers with the OBD system.
You can do an internet search for each style plug and see which one you have. The scanner will not connect to the wrong plug.
The OBD2 style is tapered on each side. The plug is under the steering column.
Jan 10, 2013 | Cars & Trucks
Which scanner should I use? OBD 1 or OBD 2?
obd1 1995 and older obd2 1996 and newer. the manual will tell you where the diagnostic port is exactly. could have 2 one under the steering wheel side of the dash and 1 under the hood. the scaner kits will usualy tell you what vehicles and what adapter to use. To learn more:obd2 scanner
May 09, 2012 | 1990 Honda Civic
Why is the check engine light is on?
Upon reaching 100,000 miles all service enging lights do come on, Have the light reset by a technician if you do your maintenance yourself
May 05, 2012 | 2008 Chrysler Sebring
I changed my oil in my 2010 chevy hhr- how do I reset the cnage oil soon light?
Turn the key on but do not start the engine. Press and release the gas pedal three times. The light should blink and then go out. Turn the key off and then start the vehicle. The light should be out. The direction are also in your owners manual. Look in the index under oil life monitor.
Aug 16, 2011 | Chevrolet Chevy Cars & Trucks
Trying to read check engine light on my 95 sunfire it has a obd2 plug but the obd2 tester wont read my codes how can i test this with out going to dealer?
Most consumer available scanners read OBDII on 96 or newer vehicles. If your car does in fact have a OBDII plug then all you need is the software in your scanner to be able to read OBDI codes...a 95 is running OBDI. Advance Auto or Autozone might have a OBDI compliant scanner for free...just tell them you have the OBDII port so they don't take up all your time digging for the adapter!
Jun 10, 2009 | 1995 Pontiac Sunfire
Autel Maxiscan Ms309 Obdii Code Reader Obd2 Eobd2 Obdii Eobdii Logo
46 people viewed this question
Top Autel Computers & Internet Experts
David Payne
David Payne
Are you an Autel Computer and Internet Expert? Answer questions, earn points and help others
