Meiko 545d machine showing 302 error
3 Suggested Answers
Kitcheneer
  • 11 Answers
SOURCE: dishwasher fix
111
Floor pan Leakage
Leak inside machine activating ground float switch
302
At pumping out during rinse cycle level does not fall below level 1
Drain pump faulty, blocked, aqua stop not closing completely, no signal from circuit board (connection number 6 on XA1 connection plug)
Posted on May 10, 2008
  • 86 Answers
SOURCE: Meiko dishwasher. Do I have an eeprom problem?
sounds like it could be a defective cylinoid switch...this will not allow water to flow properly through the machine....this is located at the water connection....try replacing and reconnect water...good luck
Posted on May 19, 2014
May 19, 2014 | Meiko Dishwashers
Error 305 on meiko dv200.2 what does it mean?
Could be a faulty booster level / pressure switch. Do you hear the air gap cup filling in the back? Could be a faulty fill solenoid (aqua stop hose with solenoid at water inlet.)
Aug 31, 2013 | Meiko DV200.2 Door-Type Dish Machine
Error 302
Check the screen and drain line for clogs or kinks. If that's not the problem, then the drain pump is faulty.
May 13, 2011 | Meiko FV 40.2 Dishwasher
Keep getting error 202 just replaced the booster rinse motor and the heating elements meiko dishwasher
it's inlet water not sufficient. 1)check inlet water is entering in to machine. 2)may be inlet water solenoid defective. 3)check the rinse water pump is working.
Jun 24, 2009 | Meiko FV 40.2 Dishwasher
Error 111 meiko dr80.2
it's water leakage inside the machine(or)water leakage switch defective.
Jun 20, 2009 | Meiko DV 80.2 Dishwasher
My meiko Dv 80 dish machine keeps showing and info code of 420. What does it mean and what should I do?
info 420 means shortage of rinse agent reported "ready for washing"state. you may have an empty or low rinse in your bottle , also could be filter on your dosing tube slightly bloked , or your doing pipe may be bloked . if not them your pump might be fauty
Apr 03, 2009 | Meiko DV 80.2 Dishwasher
ERROR 203 on MEIKO MODEL D 120.2
error 203 means , no change detected by the level switch when draining . possible cause
1, booster pump faulty
2, booster pump plug connector loose
3, start capacitor faulty
4, plug connector loose
5, boiler level switch faulty
6, no boost pump signal to- i/o pcb
7, no "boiler full" signal from i/o pcb check booster pump/ s2with manuel control
the most lightly or most common is the level switch in boiler tank will need changing
Jan 21, 2009 | Meiko FV 130.2 Dishwasher
Meiko FV40.2 Error codes
212
Boiler temperature too high
Contactor faulty, probe faulty, check connection on XA5
The code 312 is the same as a code 212 as stated above.
There are dozens of error codes and you should be able to get them from your local meiko dealer, hope this helps, colin
Mar 10, 2008 | Meiko FV 40.2 Dishwasher
Dishwasher fix
111
Floor pan Leakage
302
Feb 28, 2008 | Meiko FV 40.2 Dishwasher
Error Message coming up
Hi, i work on these machines on a regular basis and until very recently i was a Meiko service engineer- the code ERR203 means that there was no change detected at the boiler level switch during emptying- be it on the fill or rinse cycle. This fault is mostly caused by the booster pump failing to pull water but could also be caused by blocked rinse jets or a faulty boiler level switch. Hope this info is of use to you , Kitcheneer
Aug 31, 2006 | Meiko FV 40.2 Dishwasher
 Grubhead
Grubhead
