Question about Xerox Printer Division Xerox Phaser 3300MFP Mono Laser - $150 Instant
PAPER STICKS TOGETHER
PAPER COMES OUT STUCK TOGETHER
    Habit-Forming:
    New Friend:
  • 56 Answers
Probably requires separation pad cleaning/replacement
Posted on Jan 27, 2015
Shredder goes 1/3 and stops has to be reversed the forward also paper comes out punched but unshredded
its the combination of plastic parts in the shredding device . the plastic tongs part craks off then the metal binds . paper builds up in that area .
its unlikely you can fix it .
youll put ur eye out trying.
Aug 03, 2014 | Industrial Paper Shredders Office...
Printer keeps saying i got a jammed paper there is no jammed paper
There are many places in a printer where a small piece of paper can get stuck. It's not always a sheet of paper. Open all the access panels and check the roller track for pieces of paper. If it is clear, unplug the printer for a few seconds and the plug it back in. This should clear the problem if it was in error. Also check the paper feed for too many sheets stuck together jamming the feed. Before loading paper always "fan" the paper first to avoid sheets being stuck together.
Apr 14, 2011 | Canon Office Equipment & Supplies
Hi, my canon ip2600 printer is grabbing multiple sheets of paper when printing instead of a single sheet at a time. It prints but some lines of print in the final result are to compressed to be almost...
the printer is grabbing multiple paper because the paper is stuck together in cold times the paper sticks together when you insert paper into the paper try try to make the papper loose
Mar 01, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Canon MF6590 stuck in processing/data mode. Answers fax, but does not print. Go to copy, sticks in scanning mode. Powered off. No change.
Check whether any piece of paper is stuck. This may due to paper feeder/out roller may having the issue. Replace/repair will resolve your problem.
Thank you for using Fixya.
Jun 21, 2010 | Canon imageCLASS MF6590 Copier
More than 2 papers being loaded during printing
Make sure you "Fan" the Papers edge of the stack before putting in the paper tray. Make sure each piece of paper is split apart from the others before using. Often the paper sticks together from being compressed in the package.
Feb 13, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
Constantly misfeeds paper
possibility 1... the paperguides in the trays are loose... if this happens paper flops every way in the machine... (fix is simple... pull the guides together around the paper... and if they won't stay then find a way to make them stay...)
possibility 2... the feed rollers have lost their stickiness so paper slips instead of gets grabbed... ( get some rubbing (isopropyl alcohol) and a clean rag and clean them)
possibility 3... you have extremely humid or poor quality paper and it keeps jamming because it either has too many creases and holes and whatever else or it just plain sticks together and is too soft due to humidity... (store your paper in a warmer location and your copier as well)
Dec 29, 2009 | Office Equipment & Supplies
First run 2 pages fed through together. Manual duplex for the second side, pages stuck together and the whole print job a shambles. This is a new replacement today for an HL-5240L with the same problems at...
Look at the back of the printer. Pull down the back cover. Look to the right and the left of the exposed internals of the printer and there should be another handle/knob you can pull down. Pull these both down simultaneously and check to make sure there isn't a piece of paper in there or something stuck....
good luck & thanks for using FixYa
do not forget to rate the solution...
Feb 19, 2009 | Brother HL-5240 Laser Printer
Infoprint 21 paper sticks exiting output tray
I replaced the rollers that come with the consumables kit and that fixed my problem.
Apr 22, 2008 | IBM Infoprint 21 Laser Printer
Printer problem
Samsung 4100 laser printer, scanner, copier
The paper gets stuck in the roller and is not drawn up to the drum. The beginning of the problem started when the paper was never pulled from the drawer. When I open the paper drawer after a Paper Jam error, the paper is bent backward but still detached. Now it is drawn in but sticks.....margoa
Oct 16, 2007 | Office Equipment & Supplies
Xerox Printer Division Xerox Phaser 3300MFP Mono Laser - $150 Instant Logo
Top Xerox Printer Division Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Xerox Printer Division Office Equipment and Supply Expert? Answer questions, earn points and help others
