Question about Kenmore 43142 Front Load Washer
The cycle stops and reads F 2 - Kenmore 43142 Front Load Washer
  • 15,935 Answers
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
On my Ryobi BC 30 I have done a compression test and the pressure will not hold.
When testing engine compression it builds up when the engine is turning over and when you stop turning it over the compression tester has a valve in it to hold the pressure reading I think your tester is defective and not holding the pressure reading
Feb 05, 2016 | Cars & Trucks
Why is my everstar air conditioner mpm1-10cr-bb6 only show numbers 2 4 and 6
Does it cycle past 2-4-6? and if so does it stop eventually on a number?
if so i think you may just have one of the LCD numbers on the read out burned out. the lowest setting is 62 deg. so if it stops at 2 by pushing the down button then thats your problem.
Does the unit work fine besides that?
Jul 29, 2012 | Heating & Cooling
I have the Kenmore front load washer HE2. How do I use the clean washer cycle.
Hello, welcome to FixYa.
In order to perform a "clean" on the HE2 is as follows...Read these instructions completely before beginning the cleaning process.
**If necessary, the cleaning cycle may be interrupted by pressing STOP. This will stop the cycle. A RINSE/SPIN cycle must then be run to thoroughly rinse the remaining bleach from the unit. Failure to do so will cause damage to the unit and clothing added to the next cycle.**
Begin procedure
1) Open the washer door and remove any clothing or items from the washer.
2) Be sure the door is closed.
3) Open the dispenser drawer and immediately add 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment.
NOTE: Do not add any detergent to this cycle. Use of more than 2/3 cup (160 mL) of bleach will cause product damage over time.
4) Be sure dispenser drawer is closed.
5) Select the CLEAN WASHER cycle.
6) Press START.
NOTE: The basket will rotate, then the door will unlock, lock again, and then the cycle will continue. The machine will not fill, but the basket will rotate while the washer runs a short sensing cycle. This will take approximately 3 minutes.
7) The cycle will determine if clothing or other items are in the washer. a) If no items are detected in the washer, it will proceed to step 8. b) If any items are detected in the washer, all cycle lights will flash and "rL" or "F/34" will be displayed. Associated LED status lights will remain lit. The door will then unlock. Press STOP to cancel the failure code. Then repeat steps 1, 2 and 6 to start the cycle again.
8) Once the cycle has begun, allow the cycle to be completed.
9) After the cycle is complete, leave the door open, slightly, to allow for better ventilation and drying of washer interior.
Good Luck and thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Aug 14, 2011 | Kenmore HE2 Plus Front Load Washer
My top loading machine will not complete an entire cycle - it stops during the rinse cycle - so I have 1/2" of water in the bottom of my machine - Fisher and Paykel
Hi just read your posting.Now what I need to know is the model number of your machine which can be located on the back on a sticker.Also when it stops in the rinse cycle does an error code appear in you LCD screen if you have that model or do a series of lights come on and in both models it beeps.Now if you have the model where the lights come on they will be in a row of 8.Starting from the left to right what lights have turned on when it stops in the rinse cycle Is it the 2nd and 5th or the 3rd and 8th --etc-?Please reply with this additional information and I can help you rectify this fault for you.
Jun 22, 2010 | Washing Machines
Our Kenmore HE2t reads F26 and stops running half way through cycle
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Mar 09, 2010 | Kenmore HE2 Plus Front Load Washer
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
Check engine light sensors have been reset but don't show a reading
U will need to drive a mixture of stop and go, city low speed and freeway miles, this can take a week and 20-50 miles or so for the system to finish it's internal self testing. this is called a drive cycle test.
May 27, 2009 | 2002 Dodge Durango
Washer stopped draining
normally in the bottom of the unit there will be a small pump/filter assembly you need to open it up and clean the pump/filter out..run a drain cycle 2-3 times before cleaning.....have some towels ready my HE4T had this problem and still gave a small flood
May 25, 2009 | Washing Machines
Machine stops during spin cycle and reads 'ob' on the display
Read this thread about your error. I am sure it relates to your (drain) problem.
Good luck and if you have any more questions, just come back here and leave a comment - I'm happy to help.
May 21, 2009 | Kenmore Washing Machines
Kenmore 43142 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
