Question about Acer AL2216WBD LCD Monitor
Window is too large for screen
Cannot see adjustment icons in top right corner for min and max
  • 4 Answers
Well, you have to resize the monitor rsolution like make it bigger or smaller until it is fixed.
Posted on Jun 15, 2009
Some of my desktop icons have grown to be very big. I want small icons.
in windows 7 right click on the desktop and select Personalize. Then click display on the left. Choose small, medium or large.
in windows xp;
Shrinking Icons in Windows XP
  • 1 Right-click on the desktopicon1.png. A drop-down menu will appear on which you will click on "Properties."
  • 2 In the "Display Properties" box, click on the "Settings" tab.
  • 3 Slide the scale in the "Screen Resolution" box to the right to shrink the icons (and everything else that appears on the screen).
  • 4 Click on "Apply" and then click on "OK."
  • 5 Click on "Start" and then right-click on an empty space until a box that says "Properties" appears. Click on "Properties."
  • 6 In the "Taskbar and Start Menuicon1.png Properties" menu, click on "Customize."
  • 7 In the box that says "Select an icon size for programs," click on "Small Icons."
  • 8 Click on "Apply" and then click on "OK" to adjust the size.
Shrinking Icons in Windows Vista
  • 9 Right-click on the desktop. When the drop-down menu appears, run the mouse-pointer over "View" and click on "Classic Icons." This will shrink the icons if they are set to either "Large Icons" or "Medium Icons."
  • 10 Right-click on the desktop again and click on "Personalize."
  • 11 On the "Personalize appearance and sounds" screen, click on "Taskbar and Start Menu" on the left side bar.
  • 12 In the "Taskbar and Start Menu Properties" menu, click on the "Start Menu" tab.
  • 13 Click on "Customize."
  • 14 Find the box that says "Use large icons." If it is checked, uncheck it and click on "OK." This will shrink the Start Menu and Taskbar icons.
Read more: http://www.ehow.com/how_4855250_make-windows-icons-smaller.html#ixzz2ifeSGGtj
Sep 08, 2013 | Computers & Internet
Compaq desk top screen to large
Right click your desktop and click resolution. Adjust it so that it is set to the maximum possible (native) and click apply. If you're talking about metro, you should be able to scroll scroll to reach the other icons. You can also adjust icon screen size if you go to the desktop, hold the control key and scroll using a wheel, or right click and change icon size.
Nov 04, 2012 | Compaq Computers & Internet
How do I change the font or Text sizen
  1. Go into your Control Panel by first clicking on the Start Button.
  2. Then click on the Control Panel icon located in the right column of the Start Menu.
  3. If your Start Menu is set to the CLASSIC VIEW then begin by clicking on the Start Button.
  4. Then click on Settings, then click on the Control Panel icon to open up the Control Panel.
  5. Now, Double click on the Display icon to open up the Display Properties Window.
  6. Then click on the Appearance tab at the top of the screen.
  7. At the bottom left side of the screen you will see an area to change the Font Size:
  8. Use your mouse to switch between normal, large and extra large according to your preference.
  9. Then click on the OK button to save your changes and exit Display Properties window.
  10. Windows XP will immediately adjust to your new Font Size without restarting your system.
  11. Then close the Control Panel to return back to your Windows Session.
Jun 10, 2011 | Computers & Internet
Increase my font size
You did not specify your operating system.
For Windows XP
If your Start Menu is set to the Classic View, then begin by clicking on the Start Button.
Apr 26, 2011 | Computers & Internet
My ag neovo e-17da monitor everything in the screen seems to have stretched and the bottom of the screen where the arrow is to scroll up and down i cant see it its like i need to shrink the display a...
Hello Dean,
It seems your windows resolution settings are set wrong, you simply need to adjust the resolution to match the monitor. To do this, open your start menu, select Control panel. When the control panel is open check the top left corner to see if it is in Classic or Category view, if it says Category, click the switch to classic mode link. If you don't see this in the top left look at the top right and look for Category or Large Icon View, if Category is selected select Large Icon by clicking on Category and then clicking Large Icon View in the list that appears.
Once in the proper view, click on Display and depending which version of windows you have select Settings on the top of the properties window(XP or older) or Adjust Resolution from the left column(Vista/7), now find the slider bar for resolution and slide it to 1280x1024. This will set the number of pixels on the screen.
The default and best resolution for this monitor is 1280x1024, if that makes the fonts/icons too small try 1024x768 next and 800x600 last. If the resolution is set too low to see the Ok and Apply buttons simply set the slider bar then press the enter button the first time, then you will be able to see the Ok and Apply if you need to continue adjusting.
Hope this helps FixYa,
Chris
Reply back with your version of windows if you require more specific instructions or pictures of any of the steps.
Jan 02, 2011 | Neovo E-17 17" LCD Monitor
How do I reset the monitor to correct font size
Hello Lawrie,
You don't actually adjust fonts or resolution on the monitor, you do adjust them in the control panel of the computer. To do this, open your start menu, select Control panel. When the control panel is open check the top left corner to see if it is in Classic or Category view, if it says Category, click the switch to classic mode link. If you don't see this in the top left look at the top right and look for Category or Large Icon View, if Category is selected select Large Icon by clicking on Category and then clicking Large Icon View in the list that appears.
Once in the proper view, click on Display and depending which version of windows you have select Settings on the top of the properties window(XP or older) or adjust resolution from the left column(Vista/7), now find the slider bar for resolution and slide it higher if you want the font smaller or lower if you want the fonts larger. This will set the number of pixels on the screen.
The default and best resolution for this monitor is 1280x1024, if that makes the fonts too small try 1024x768 next and 800x600 last. If the resolution is set too low to see the Ok and Apply button simply set the slider bar then press the enter button the first time, then you will be able to see the Ok and Apply if you need to continue adjusting.
Hope this helps Fixya,
Chris
Jan 01, 2011 | LG Flatron L1750S 17" LCD Monitor
New Acer 5532 laptop; v.wide screen but not v.deep. Currently, large toolbar icons take up some 25% of the screen unecessarily - how to reduce their size down ?
Depends on which Windows version you have, unstated.
Right click on screen anywhere except other icons, go to "properties" and adjust screen res to max and also check under appearance that icons are "normal"
Mar 30, 2010 | Computers & Internet
Calibrateing
With Windows XP in the lower-right corner of your screen is the Notification Area where there are a bunch of little icons. There should be an icon that looks strikingly similar to your Kodak 5100 AIO printer. Double-clicking this icon will bring up the printer's status window. In the top right-hand corner of this window there are three icons. The first from the left is the maintenance icon that looks like a crossed hammer and wrench. After clicking this icon it should become obvious how to calibrate your new ink cartridges and printer heads.
Dec 03, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Adjusting window view
If you mean that your Windows desktop does not fill your screen, use the monitor screens menu to adjust the settings and make it fit the screen. If you mean the windows you view within your desktop do not expand to the edge of the screen, click the middle icon in the top right corner - between the _ and the x this should maximise the windows. For further info you will need to post more information about what equipment makes and models you are using. May also be better if you posted your problem in the correct section. This issue has little to do with speakers me thinks. Let us know how you get on.
Sep 28, 2007 | Audio Players & Recorders
Acer AL2216WBD LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
