Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
Mine is doing the same forwad 2 or 3 feet
Are there any solutions to this problem?
  • maintenan303 Jun 30, 2009
    the first solution did not work
  • maintenan303 Jul 09, 2009
    !st and second solution did not work manual not much help
  • 258 Answers
Ok...with the Robo- Kleen, just simply, read the manual. The manual contains every piece of information of that you will ever need. But often times homeowners just don’t take the time to read.
You will find out how to set up your Robo- Kleen, what safety concerns there are and what to look for in case of problems. The manual will even give you information on where to find replacement parts...and like the other expert has said open it up as much as you can to clean the dirt and junk out off it, especially around the wheels...also check all the plugs and wires are connected, if they are loose tighten them, then after power off and on and see if it now works..also if you don't have your manual click the link below or put into your internet browsers address bar up the top and click enter ok...good luck thats the best advice I can give you
www.poolcenter.com/Robo-Kleen_Manual.pdf
Posted on Jun 30, 2009
    Genius:
  • 1,847 Answers
You might first check that the impeller is not clogged with any debris. remove the screen on top and inspect. and, check around the wheel axles for foreign matter wrapped around them. It is also very important not to run the unit out of the water or try to manually turn the wheels. Let me know. Thanks K
Posted on Jun 15, 2009
I have a Chevrolet Impala 2011 the driver side set used to move forwad and backwards but not up and down. While cleaning my car tonight I moved the seat forward and now it wont go backwards. It was making...
you may have just over run the end stop , try sitting in seat and whilst pressing the back button push with your feet against the floor , this might get the seat moving again , if not i think you may be looking at getting a new switch , but get it checked by a mechanic first as there may be some other way to get it moving
Jul 02, 2014 | Cars & Trucks
1998 buick lesabre 3.8. Replaced starter. jumped it with screw diiver across the 2 posts on the silinoid. it engages but wont turn over. tested the small wire with iginition turned forwad and has 0.0010...
jumped it with screw diiver across the 2 posts on the silinoid. it engages but wont turn over.??? Engine is locked up ,seized up .. get a new engine
Jan 17, 2018 | Buick Cars & Trucks
How to solve this problem in a different way,A FARM BOY TENDS PIGS AND CHICKENS IN THEIR YARD,hE COUNTED 21 HEADS AND 54 FEET. hOW MANY PIGS AND CHICkENs ARE THERE?pls.share me a strategy without using...
P = number of pigs
Then P is the number of pig-heads, and 4*P is the number of pigs-feet.
C = number of chickens
Then C is the number of chicken-heads, and 2*C is the number of chicken-feet.
Thus: 21 = P + C
Equivalently: 42 = 2*P + 2*C
Also: 54 = 4*P + 2*C
Thus (54-42) = 4*P + 2*C - 2*P - 2*C
Factoring: 12 = 2*P + ( 2*C - 2*C)
Reducing: 6 = P
Or, do it on graph-paper, with 'P' on the X-axis and 'C' on the Y-axis,
and each unit representing one animal (pig or chicken).
Draw one line between (0,21) and (21,0) (no pigs & 21 chickens, versus 21 pigs & 0 chickens)
Draw one line between (0,27) [no pigs and 27 pairs of chicken-feet]
and (13,1) [13 pigs have 52 feet, with 1 pair of chicken-feet]
The two lines cross at exactly one point on the graph, namely at the solution.
Feb 03, 2011 | Computers & Internet
I Am installing a Generac 20Kw air cooled unit with a 200 amp service disconect ATS What size conductors do i use from the generators 100 amp breaker to the transfer switch
It is always good to install a large enough wire where the maximum load can be drawn plus a little extra for safety. 7 gauge wire will do, if it was mine I would use 6 gauge wire. If the length is over 20 feet but not longer than 80 feet go to the next larger size wire.
Dec 18, 2010 | Generac Guardian RTSE200A3 200 Amp...
Display showing "E" and film is not getting forwaded
It sounds like the film transport motor is dead. If so, it needs a trip to repair shop.
be sure batteries are inserted correctly.
Jan 12, 2010 | Nikon F65 35mm SLR Camera
How to operate a whirlpool fl 5053 washing machine
Dear Sir,
How to operate fl5053-500 model whirlpool washing m/c (fully automatic),
pls forwad manual for mail id.
this is my mail id = rajan_raman@yahoo.com,
solution = a picture or video is helpful for as,
pls reply me on further information by mail.
thanks & regards ,
raman.
Nov 14, 2009 | Whirlpool Washing Machines
2006 Chevy Impala Remote Start Poor Range
Yes some do some don't, my 2005 Dodge 200-400 feet, my 1996 Corvette 20 feet, my wife's 1998 Buick about 50 feet, is the remote battery ok? should be changed at least once a year
Dec 03, 2008 | 2008 Chevrolet Impala
Range?
hey,
regarding the range i dont think its this less i mean 2-3 feet, mine works at some 5 feet also
Try replacing the batteries, if that doesnt help i guess the receiver is not able to receive the signals properly because of some obstruction. Try and put the mouse in clear sight of the receiver.
If still the problem persists.. check out your mouse range from its website.
Cheers
Kushal
Aug 26, 2008 | Dynex Wireless Optical Laptop Mouse
Configure with utorrent
1.) To set up a static Ip address on your computer, click start, control panel, network and internet connections, network connections, right-click on local area network, click properties. In the window select tcp/ip, then click on the properties button.
Since your default gateway address is 192.168.2.1. Click on the selection titled 'Use the following ip address' Your Ip address should be 192.168.2.2, subnet mask 255.255.255.0, default gateway 192.168.2.1. Then in the next section click on the selection titled 'Use the following DNS server addresses' Preferred DNS would be 192.168.2.100 and alternate would be 192.168.2.200. click ok and you are done.
2.) As for the second problem, refer to the following link from the intellinet website. http://portforward.com/help/pfprogression.htm
Mar 05, 2008 | Intellinet Active Networking Intellinet...
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
226 people viewed this question
Top Smartpool Pool & Spa Experts
Marvin
Marvin
Craig Butler
Craig Butler
Robert Plante
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
