Question about Pride Mobility Pride Pursuit XL 4 Wheel PMV Electric Mobility Scooter
Pride Pursuit XL...I have had 3 sets of front tires go bald.
Front tire wear
President club car golf cart front tires wear out every 3 months.
Maybe your front end alignment is off?
Measure the distance across the front of the front wheels and across the rear of the front wheels.
On this cart the measurements should be almost exactly the same.
Measure carefully as the measurement needs to be exact.
If the measurements are not the same,adjust one or both tierods to make the distance between the front and rear of the front wheels the same.
TIP:AVOID sharp turns on pavement which will also accelerate tire wear.
Apr 08, 2017 | Cars & Trucks
Ford explorer eddie bauer 1998 front passenger tire bald in one spot what causes it
Doreen, the radial belt has become faulty, replace tire immediately.
Mar 07, 2016 | 1998 Ford Explorer
Front tire wear
Hi, Have you done a wheel alignment. If thats not the problem.
Try slowing down. Drive at posted speeds and check your tire pressures.
Apr 01, 2014 | Pride Health & Beauty
Rear Tires: Balding
if it has independent rear suspension then have the suspension rubbers checked and replace if necessary. Next for all wheel alignments it is essential that the rear end is aligned first to stop this tyre wear before the front wheels are aligned . IF you have leaf springs at the rear check for axle alignment and broken centre bolts or worn rubbers at the centre bolt mounts.
Mar 24, 2014 | 2003 Buick Rendezvous
Inside of front tyre going bald
Just one tire or both? Likely you need an alignment done, but other things can cause tire balding and cupping. Brakes pulling to one side or other can also cause tires to wear prematurely and unevenly. Worn Shocks/Struts are also culprits. Worn or broken bushings in the suspension. Also, bearings starting to seize up can cause this as well. In other words, a BUNCH of things can cause the problem. If you have no issues with steering, handling, braking, it is likley just a simple alignment is needed. Take it in to a reputable place and they can diagnose the exact cause and suggest repair needed. Good luck.
Mar 18, 2014 | 1998 Honda Odyssey
Roaring from passenger tire with excessive wear
if the tire wear is that dramatic there is something definately wrong. also a major saftey issue. it could be a multitde of issues. shocks, alignment, etc...
Mar 12, 2014 | Pontiac Cars & Trucks
Pursuit XL scooter, rubbing sound during right turns...
My first guess is that you have either loose lug nuts(5)on one or more of the wheels, or you have loose screws(6)that hold the wheel rims together as these have split rims. This is more common on scooters with flat-free tires as the tire and the foam insert will chafe against each other and produce a rhythmic sound as the wheel rotates. Try tightening all of the lug nuts first and see if that helps. If it persists, try removing the tire by removing the 5 lug nuts and pulling it off the axle. You'll see six bolts that hold the rim halves together. Re-tighten all of these and install the wheel to see if that cleared the noise. Note: The real wheels have a key-slot in the axle and a key which slides into this slot to hold the tire to the axle. Be careful not to lose the key when you slide the wheel off, and be sure to get the key back in the slot when you install it back on the hub. Here is the page for your scooter. Click on the owners manual and scroll down to page 37 for info on tire removal.
Jan 10, 2013 | Pride Mobility Pride Pursuit XL 4 Wheel...
Uneven tire wear and struts problem
Sounds like you should have the alignment checked on an alignment machine on all 4 wheels.Once you get those readings and an expert alignment mechanic's estimate on repair,only then will you know the correct repairs needed.
Apr 28, 2017 | 2004 Honda Accord
2002 E320. Premature tire wear on right rear wheel.
THese cars have a high speed rated tire and will almost always wear quickly. The right rear is the drive wheel (where the power goes when you give it gas) It will wear real quickly if you drive it hard. I would try rotating every 7500 miles (unless tire sizes are different as with the SL series) I sell a lot of tires on these cars and 25K is usually the limit.
Feb 01, 2009 | 2002 Mercedes-Benz E-Class
2000 sable...right front tire bald?
It could be wheel bearings/hub, ball joints, bent a-arms, or a-arm bushings. Good luck
Dec 03, 2008 | 2000 Mercury Sable
Pride Mobility Pride Pursuit XL 4 Wheel PMV Electric Mobility Scooter Logo
27 people viewed this question
Top Pride Mobility Health & Beauty Experts
Robin Hill
Robin Hill
jeff tilburn
jeff tilburn
Scooter Doctor
Scooter Doctor
Are you a Pride Mobility Health and Beauty Expert? Answer questions, earn points and help others
