Question about Philips DVDR3380/05 DVD Recorder
NO SIGNAL FROM DVD NO LASER LIGHT
NO VIDEO OUTPUT, LASER THAT CAN NORMALLY BE SEEN FROM UNDERNEATH NOT ON
How to connect samsung dvd to samsung tv
Follow these steps: Component Video Connection 1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
2 Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
3 Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
4 Match the connectors to the appropriate video input jacks on the TV.
If using S-Video Connection
1 Get an S-video cable. This cable has a single round connector with 4 pins.
2 Attach one end of the S-video cable to the S-video output jack on the DVD player.
3 Attach the other end to the S-video input jack on the TV.
Composite Video Connection 1 Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
2 Plug one end of the composite video cable into the composite video output jack on your DVD player.
3 Plug the other end into the composite video input jack on your TV.
May 14, 2011 | Samsung Televison & Video
No hdmi funktion to my new LED TV.
Most likely the output from the Pioneer is not compatible with the TV.
Try resetting the output by holding Stop (on the pioneers front) and press the Open/close button. This will reset the output signal. Also, if the harddrive in the Pioneer is defect, the HDMI signal will not output.
Jan 12, 2010 | Pioneer DVR-550HS HDD Recorder
My DVD player / recorder keeps kicking out the discs I put in. It won't even read them. the screen says close and the tray comes back out almost immediatly. Now it's gotten so bad that the tray won't come...
How old is your DVD recorder/player?
It sounds like it needs a service!
The usual problem with DVD players/recorders not reading discs is that the laser output is starting to fail - and consequently the laser light emitted is insufficient for the system to "read" through the minute "holes" in the disc.
It's possible to have the laser replaced, but this would cost you at least £50, depending on where you live.
Initially, you could try buying (or borrowing) a laser cleaning disc. These cost around £3 to £5 depending on where you buy & live, and have a small brush on the lower side of the disc. Insert this into your player and run the disc for a couple of minutes. If there are any dust particles that have been blocking the light output from your laser head, then this may remove it and might solve the problem.
If this fails, then it seems likely that the laser head is not producing enough output and would have to be replaced with a new one.
Also, you could try playing a CD on your DVD player as these discs contain far less information than a video disc (DVD) and the laser head may be able to cope with this.
If the CD plays ok, then you will know that the reason why it won't play DVD's is the light output has started to fade due to the age or excess use of your system.
Nov 17, 2009 | Sony Televison & Video
On our Durabrand DVD/Vcr Combo, I get picture, but no sound..I'm using a S video as conectors!
S video connector is used only for video, you need to connect the audio separately via the RCA audio connectors or via digital coaxial or optical connector.
You can read more on S video standard here:
http://en.wikipedia.org/wiki/S-Video
Also see the related topics on audio, maybe you should consult the user manuals for your dvd unit and the amplifier that you use to get more info, but normally the sound can be connected via these connectors on the rear panel of dvd units:
- main left and right analog signal out RCA connectors (2 channel stereo signal - amplifier set to analog signal)
- main left and right, sub, center, surround left and right analog signal out connectors (multichannel surround signal - amplifier set to analog signal)
- coaxial digital signal out RCA connector (a single cable that takes the stereo or surround signal to the amplifier in a coded digital form - you need to set the amplifier to the digital signal mode to enable this kind of signal)
- optical digital signal out connector (same as the coaxial digital output, the difference is that the signal is in the form of light pulses instead of electrical pulses - the amplifier should be set to the digital signal mode as well)
Hope this helps somehow - if it doesn't, post me some feedback, perhaps a brief description of the units that you want to interconnect...
regards
Triarcuate
Sep 26, 2009 | Televison & Video
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
No component output on AVR-4306
This does not work... You can only upscale the video signal with 4306; meaning you can covert s-video, component video to HDMI but can not down-convert HDMI input (coming from your HD DVD player) to Component video output. Sorry that I could not give you a solution as this is the 4306's limitation (written on the 4306 manual.).
Nov 21, 2008 | Denon AVR-4306 Receiver
Waiting for input signal
It's a protected video. The VRD-MC5 will not burn a VHS or input that has been protected.
Jan 09, 2008 | Sony DVDirect VRD-MC3 DVD Recorder
No Audio/Video output with DVDs
lost dvd picture and menu screen through denon av2307 composite conection
Aug 26, 2007 | Denon DVD-3910 DVD Player
Hi Def from dvd player
Tony, Let me ask you a silly ? as Im sure you can answer your own ?. Is your TV Hi def?? NO?? Ok Is your DVD player HI def campadable? Yes. Does your DVD player have RCA outputs for video or s video Output?? Yes. Ok Tony if your TVs not HI def how do you expect to get HI def out of it??? Use rca outputs as it is compadable. if the DVD player has no s video or RCA jacks and I've not seen one yet that didnt then your going to have to get one that does. Good Luck
Jul 30, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Philips DVDR3380/05 DVD Recorder Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
