Question about Sentry Fireproof Safe
Try to open 1150 without key
Need to open
My 1150 dell inspiron laptop wont let me pass the bios screen this is my second one that has just out of nothing password protected just decided to all of the sudden have a admin or bios password ...
Disconnect the battery, unplug it, then open it up. There should be a small round battery called the CMOS battery somewhere in there. Pull that out. Then plug your computer in and boot it up without the CMOS battery. It should say password disabled. Turn it off, disconnect it, put it back together, and you're good to go.
Jan 10, 2011 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell 1150 laptop configuration module problem
Hi, you can perform a system restore by accessing safe mode by pressing the ESC button during bootup. Restore system to a time before the problem began. You will need to perform a full virus scan straight after normal bootup is achieved. Hope this helps
Jul 15, 2010 | Dell Inspiron 1150 Notebook
I would like to know how do I find the battery power remaining on my inspiron 1150 laptop computer. What keys do I use on the keyboard to locate the backup battery power. Thanks,
In the right bottom corner of the screen in the system tray you will find and icon that tells you about the battery when you move the mouse over it. If you click it open you will get more info and an opportunity to change things.
Dec 31, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
I put a dvd in my dell inspiron 1150 combo dvd cd andit will not
Uninstall the program and reinstall it,
maybe the disk with the drivers will solve your problem,
if no disk download the drivers from www.dell.com
or try the manufacturer ofr the dvd drive for the drivers too
also what Service Pacxks do you have installed on this machine
XP will need at least SP2 for some of you high speed devices ie usb2.0
Good Luck MISTERDJ
Aug 16, 2009 | Dell C3039 Inspiron 1100, 1150, 5100,...
Dell Inspiron 1150 - Wont boot & nothing on screen ??
The fans on this unit are thermostatically controlled and only turn on when the predefined processor temperature is reached, so upon turning the unit on It will spin up too full speed and then seem to shut down until it is needed.
If you are getting no beep tones and since you have already tested your memory, I am forced to assume that either your processor has retired or your cmos is wrong, Since you sound like you have already opened the unit then locate the clear cmos jumper/switch on the board and clear your cmos which will reset to defaults.....if you still have the same problem then I reccomend trying a different processor.
Ed Meyer
May 24, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Need to install GPS on BMW 1150 GS...have no manual...how, please
Check your owners manual for location of your fuse box. You will probably find connections for accessories. If not make sure you use an inline fuse on the positive connection and then ground to the frame.....Good Luck and Nice Bike!
May 08, 2009 | 2002 BMW R 1150 GS
Canon CLC 1150 Boot Problem
your lcd screen is damage replace it
Sep 14, 2008 | Canon CLC 1150 Color Copier
Power problem
There is no exact name for this main board. All you need to know when replacing the main board is that the Insp 1100 and The Insp 1150 main board will fit. If you are going to change out the board, I suggest going with the board from an Inspiron 1150, it is an upgrade for the Insp 1100, and has built in wireless.
Sep 02, 2008 | Dell Inspiron 1100 Notebook
Inspiron 1150
without the windows xp installation cd there is not much you can do, but if you have it... you can do this.
REMEMBER: all this is considering you have a normal computer, with a normal system and your hardware is not damaged.
Your problem is very generic and the information you are providing is very poor...
boot with that installation cd
let windows xp installation start and when it prompts you to choose between installing or repairing by pressing "R" key, choose this second one and wait till the system shows you a black screen with some lines of white text on it.
you will be now able to write on that console DOS like... type this three commands and when the firsts two ask you, choose YES.
1. fixboot
2. fixmbr
3. chkdsk
the last one will check the hd and will tell you if you have problems in that hd... if it shows problems, after this, you should replace HD so...
after that just reboot your system and see if it works...
TIP: BOOT UP WITHOUT ANY THING BUT KEYBOARD AND MOUSE, disconnect printers, scanners, any usb dispositive, just keyboard and mouse...
if not give me more info on this please.
Mar 14, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Inspiron 1150 Wont Start Up
try taking out the memory.you can have the instructions by going to this link---http://support.dell.com/support/edocs/systems/ins1150/sm/upgrades.htm#1105389.Incase that does not work than i would suggest to get the motherboard replaced.You can contact the tech support incase you have the warranties and get it replaced
Dec 22, 2007 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Sentry Fireproof Safe Logo
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
