Denon DRA-685 Receiver Logo
Posted on Jun 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I plugged my Macbook into my Denon DRA-685integrated amp. I can a lie from the headphone out on the Macbook to the "audio line in" in back. I got great sound through my speakers, although, I had to control the volume form the Macbook. However, I am now unable to get sound through my Denon from any of the other sources which are hooked up - i.e., DVD, cable TV, etc. What should I do?
Anonymous
Level 3:
Genius:
  • Master 1,847 Answers
  • Posted on Jun 15, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1847
Questions
Helped
553218
Points
4940
You have six stereo inputs labeled Turntable, Tape Recorder, CD Player, DVD Player, VCR, and Video Aux, you have change the Aux (Use remote) according to get sound of the other device.
Let me know
Thanks
K
2answers
Why am I not getting sound anymore?
Amplifier issue. See if you are getting audio signal at audio outputs used for recording. If not, then it is NOT the audio amp and the proceeding circuits are responsible.
U might also want to check out your power supply voltages to make sure that the other components are being properly fed.
I have a Denon (receiver) DRA-825ra that has this issue: It powers on and you hear the first click sound right away, but the second click sound after five seconds does not activate. Can you help me...
Try plugging in headphones to the headphone jack, then take the plug out. Some models of Denon receivers had faulty headphone jacks in them that caused the unit to think there were headphones plugged in even when there wasn't.
1helpful
Can dra 37 be used as a pre-amp without connecting speakers
If you mean a sa control center for source selection, volume and tone control, yes, but NOT for a turntable (no PHONO).
Controlled audio goes emerges from the pre-out. Page 9.
http://www.retrevo.com/support/Denon-DRA-37-Receivers-manual/id/696dj086/t/2/
But you could still use its own speaker terminals if your exxternal amp has is remote or has its own volume control to match it up with other speakers.
4helpful
Is the denon dra-395 compatible with an ipod?
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
Denon dra 397 shuts done if I turn on both zone a & b. Have a 100 watt volume control on each pair of speakers. Works fine with only zone a or zone b on, but not both.
Let's understand this - you have an external volume control wired in series with each front speaker set?
Can you elaborate on their electrical characteristics?
http://www.retrevo.com/support/Denon-DRA-397-Receivers-manual/id/696dj087/t/2/
Page 24.
A + B 8 - 16 ohms
1helpful
Looking for Denon dra 1025r Service &/or user manual
I have a Denon Dra-1025R operating instruction book,if this what you need and I can offer some info let me know
What excatly do i need to connect my ipod to the Denon dra-f102
All you need is a 3.5mm mini jack to 3.5mm mini jack stereo lead, plug one end into the "portable in" input on the denon receiver and the other into the headphone input on your ipod. Et viola.
2answers
Connecting new tv to DRA-685
you can use the headphone jack just get an adaptor to change from the headphone type to RCA type. adjust the volume of the tv to 3/4 of the way to give line level to the stereo, use an aux input on the stereo. if you had a suround sound dolby digital / DTS receiver then use the digital coax out to that type of receiver, but since you have an anolog 2 channel receiver you must use the only anolog source (the headphone).
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
