Question about Keurig Platinum B70 Coffee Maker
Turn off auto start
How to completely turn off programmed auto start time?
Setting the clock on a brinks timer 44-1011
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Dec 24, 2012 | Hardware & Accessories
Breville you brew auto start not working
There is an error in the manual. Following the directions will, as you discovered, start brewing immediately.
To complete the auto-start programming, in step 8 of "Programming Auto-Start" you should NOT "press the PROGRAM button."
Instead, as soon as you have set the desired minute of the Start Time (step 7 in the manual), press the START / CANCEL button.
The LCD screen will then dim and display 'PROGRAM ON' to indicate that the Auto-Start feature has been successfully turned on.
Hope this helps.
- Owen.
Sep 13, 2012 | Breville You Brew - Single and Carafe...
Can't get it to auto tune
Hello
To set the TV to autotune do the following.
1 Press "Power Button" to turn on the TV. The Initial Setup screen appears
2 Press CH UP button on the remote control or on the TV front panel to start Auto Program, or press CH DOWN button to Exit.
When you start autoprogramme, wait until it is finished; otherwise it will skip over channels that are available. If it happens so, perform autoprogram again by turning on the power button.
The initial set up screen appears each time you turn on TV until you perform auto program.
To perform Auto Program again
1 Press "Menu" button.
2 Press"=>"to highlight Channel Menu.
3 Press "Down arrow button" to highlight Cable. Press "+" button to select.
4 Press "Up Arrow button" or 'Down arrow button"to highlight On or Off according to how you connected your TV. Press "+" to select.
5 Press "Down arrow button" to highlight Auto Program. Press [+] to search for channels
6 After Auto Program finishes press "Menu button" to exit.
To reset the TV to factory settings
1 Turn the TV on.
2 Hold down [Reset key] on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release [Reset] key.
Ok.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do you set the clock and program to brew at a specific time?
To program the Auto On
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
Aug 16, 2010 | Cuisinart DCC-1200 Coffee Maker
Auto door lock want work
The auto door lock feature is a programmed feature that can be turn on or off. to enable or disable this feature you will need to follow these directions.
1. Close all door and place the key in the ignition switch.
2. cycle the ignition switch ON/OFF four times ending in the OFF position. (do not start the engine.)
3. Within 10 seconds of the final cycle, press the interior driver's door lock switch to the Lock position.
4. A single chime will sound to signify that you have successfully completed the programming.
You can turn this feature back off by performing the above procedures again.
Jul 29, 2010 | 2005 Dodge Caravan
Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Philips Magnavox TP2784C TV always powers up to Channel 9
Unplug unit from AC outlet for 10 - mins then plug back in to AC. Turn unit on select channel 3 turn off and back on.
May 18, 2009 | Philips TP2784C TV
Need assistance on how to program the timer for my cuisanart 12 cup coffee maker
The manual can be found here:
http://www.cuisinart.com/share/man/25_man.pdf
Mar 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
I cannot get the auto start to turn on. The times are properly set. Does the Program green light need to be yurned on to auto start or what?
You have to set the coffemaker to AUTO-ON for it to turn on at a set time in the morning. The PROG function is merely to set the right turn-on time. Once this time is set, you must switch the coffeemake to AUTO-ON.
-Tha Mp3 Doctor
Mar 20, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
Turn the TV on.
2 Hold down on the remote control.
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Keurig Platinum B70 Coffee Maker Logo
19 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
