Question about Viking VMOS200 Microwave Oven
Digital display doesn't light
The digital display on my Viking drawer microwave does not light up enough to read from any distance.
Will not power up
If you wish to get some details; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
Jun 12, 2016 | Viking VMOR205SS 1.1 Cu. Ft....
Viking microwave vmos200
mine did the same thing took back apart cleaned put back togerther no fix bout new one
May 10, 2013 | Viking VMOS200 Microwave Oven
The microwave doesn't work at all. no display, light, anything
Plug a lamp in the wall receptical in place of the microwave oven, if okay! it means the main fuse in the oven has blown. There are a number of reasons why this happens, a bad fuse, door switch that has malfunctioned, "common" cracked high voltage diode, shorted capacitor, and an open magnetron. I suggest a professional.
Mar 09, 2012 | Panasonic Microwave Ovens
Re. Viking DMOS200 1100 watts microwave oven does not turn on
I'm guessing that's a VMOS200?
If so, that's a rebranded Sharp R-530ES (as is the Dacor DMO2420S) and its secondary interlock (bottom door switch) or that switch's mount is bad.
See this file on door switches. If you only need a switch, you can order a universal type here for $5 postpaid.
The Sharp R-530E service manual will aid you in disassembly and it is here.
Jul 02, 2010 | Viking DMOS200 1100 Watts Microwave Oven
Sharp Insight Pro microwave drawer KB6024MS not working
The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
1) Push the draw all the way closed
2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
3) Hold the Start Button until the time reappears in the display.
4) Repeat steps 2 & 3 three more times
5) Unplug the Microwave for 30 minutes.
The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Feb 05, 2010 | Microwave Ovens
Viking microwave has digital lights but will not turn on to cook?
Hi the problem will be with the touch panel membrane or the controller. if yoiu can hear a click when the start button is pressed then the touch panel is OK asnd you should look at the controller which can be replaced as a unit or if you are up to it it's probably the main cook relay that has failed.
Jan 29, 2009 | Viking DMOC205SS Microwave Oven
Viking VMOS200 Microwave Oven Logo
37 people viewed this question
Top Viking Microwave Ovens Experts
William Miller
William Miller
Colin Stickland
Colin Stickland
Gerry Harvey
Gerry Harvey
Are you a Viking Microwave Oven Expert? Answer questions, earn points and help others
