Question about Copystar - CS-3035 Printer
Connect copier to computer
Printer from computer to copier
How to print to Canon ImagePASS-M2 (connected to iR105) from Windows computer
If you connected it directly to a Windows computer, then, on that computer, "share" that printer, so that any computer that can connect to that computer can also access that printer.
You probably need to download software from Canon's web-site and install it on each computer that wants to print to that printer/copier.
Apr 29, 2014 | Canon Office Equipment & Supplies
Yellow light blinking
Typically, printers will blink a yellow light to indicate a communication problem between the printer and the computer.
1. Shut your printer and computer completely down.
2. Check connections to printer
3. Follow connected printer cables to the related computer port.
4. Check connections to computer
5. Turn the computer on and let it boot up
6. Turn your printer on.
Jan 20, 2013 | Office Equipment & Supplies
Is there an interface to make this a printer
You will need to use a Parallel Cable to connect this copier to a computer. Many newer computers do not have parallel connections - so you may have to purchase a USB to parallel cable to get the job done for you.
I found a link to the manual for this copier here: http://www.manualowl.com/m/Sharp/AL-800/Manual/212853
Hope that helps!
Nov 14, 2011 | Sharp AL 800 Copier
Brother mcf-8220 - printer has been successfully installed on my computer but it won't print.
Does the all in one printer work stand alone as a copier?
What type of connection is the printer using to connect to the computer?
Jun 04, 2011 | Brother MFC 8220 All-In-One Laser Printer
NP 6050 Copier: connect with computer...
Sorry the Canon NP 6050 cannot be connected to your computer. this type of copier is an Analog copier. if you wish to have a copier that can be connected to computer you need a Digital Copier with printer and scanner option.
May 17, 2010 | Canon NP 6050 Copier
How to connect it with my computer
Connecting any NP series Canon copier to a computer is not possible. This is an analog copier and did not have the capability to be connected to a computer for use as a printer.
Apr 15, 2010 | Canon NP 6035 Copier
Connecting my computer directly to konica 8020
You can hook the copier directly to your computer using a USB cable.  You can purchase one at any computer store.
Oct 20, 2008 | Office Equipment & Supplies
Connecting one printer to two computers
start, settings, printers, right click printer you are wanting to share out. Click on properties.Click "sharing" tab. Click on network setup wizard. Follow the instructions from there. You should be able to print to the printer from another computer once your computer network is setup to share resources like printer or internet connection.
Apr 20, 2008 | HP Deskjet F340 All-In-One Printer
Connecting it to computer
Hi. After you get your cables connected from your computer to copier select control panel, click on add printer and it should what kind of copier your have. If it shows you copier then select it and it should automatically add it to the computer and follow the steps from the computer after that.
Mar 25, 2008 | Canon PC-D320 Copier
Copystar - CS-3035 Printer Logo
19 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
