Question about Maytag Microwave Ovens
Light under hood keeps blowing on MMV4205 AAQ
Under hood light keeps blowing.
I have a maytag built in microwave MMV4205BAW from August 2006. The microwave runs but does not heat and makes a slight buzzing sound. It sounds like the magnetron needs to be replaced. If this is not...
From the description it is the magnetron, it will be expensive for the part alone, and keep in mind shops have different rates making impossible to give exact quotes, but I would estimate parts and labour at least $250.00 or more, if you decide to go with the repair make sure the magnetron is not a aftermarket product it will last about 6 months.
Jun 16, 2012 | Maytag MMV4205 Microwave Oven
The exhaust system never has worked. Will not pull any air from the cooking stove under micro as it was supposed to.
Check the cabinet over the top of the microwave, the unit should be vented to the outside of your home, if not it was a venting model and just never connected to the vents.
I’m happy to assist further over the phone at https://www.6ya.com/expert/gregg_78ecbb34e27be215
Jun 14, 2010 | Maytag MMV4205 Microwave Oven
MMV4205BAS no power. Was not using it.
Try checking the fuses under the button panel.
Jun 08, 2010 | Maytag MMV4205 Microwave Oven
Our Maytag microwave died. The outlet has power.
you have to remove the cover, un-plug the power cord=
un-screw the screws located behind the unit and on the sides if any also under side if any, remove cover and you will locate the fuses and other components behind the key pad, also check slow blow or thermal fuse usually located on top of oven. NB: HIGH VOLTAGE COMPONENTS PROCEED WITH CAUTION!!!!!!!
Mar 25, 2010 | Maytag MMV4205 Microwave Oven
Unit just died for no reason?
Take the cover off...comes apart many different ways on various models. Once cover is removed look for blown fuses...should be one on the main input near the power cord. May be additional fuses at the transmitter. Could also be as simple as removing input power for 15 minutes and then reconnecting; I recommend you try this step first.
Feb 07, 2010 | Maytag MMV4205 Microwave Oven
When I was unscrewing a burnt out hood lamp on
I would not use the lamps. Sounds like there is a shortage in the wiring for the lamps. They lamps should run together, and if one of the sockets have a short or burned wire it will not let it complete the circuit. This could be a fire hazard, so I would replace the whole microwave. It would be more trouble to tear it apart and find the exact problem than it's worth.
Jan 04, 2010 | Maytag MMV4205 Microwave Oven
Light
did the side with the hole have a clear or frosted cover? If so look up inside the hole to see if the socket may be pushed back up insde.
Aug 24, 2009 | Maytag MMV4205 Microwave Oven
Maytag Microwave 1150 Help
Check first the motor coupling under the turntable, if that is not the problem , then test and eventually replace the turntable motor.
Click here and select model to get parts and diagrams.
Apr 05, 2009 | Maytag MMV4205 Microwave Oven
Light socket is dead on my Maytag
Yes, this is caused by not disconnecting the microwave from the power line when removing or installing a bulb or by the filaments shorting when the bulb blows. This is a problem with the control panel assembly, which we repair nationwide for $39.95. If you or a friend decide to send it to us, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 01, 2007 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
15 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
