Question about Philips CD535 Cordless Phone
No incoming ring tone
Everything working well on phone except no incoming ring tone
No ringing for incoming calls. Have tested ring tone/volume on set everything seems OK.
May be one thing is missing i.e. Go to tone setting>>and check the "Alert Type" it should be in "Ringing".Good luck
Jul 28, 2011 | Cell Phones
How do i change the ringtone callers hear when they contact my htc wildfire
Thanks for visiting FixYa!
In most cases, the ring tone callers hear (incoming ring tone) is controlled by your cellular service provider.
Try this first: (On the Internet) Sign-in to your cellular account. On your account page, look for a link that directs you to your incoming ring tones (or similar). There, you can change your incoming ring tone.
If you're unable to do that, contact your cellular provider's Customer Support. They can assist you in changing your incoming ring tone.
May 30, 2011 | HTC Wildfire Cell Phone
Ring tone
In most cases the ringer has been inadvertently turned off or too low. You can turn it back on from the system menu and can also try by increasing the volume control while the phone is idle.
May 01, 2010 | Uniden DECT 6.0 Cordless Telephone...
Cellphone does not ring, or message tone
well you say that the music player is working..so there isnt any problem with the speakers..I suggest you better check de settings -> tones -> incoming call ! or settings -> tones-> incoming msg..check as they maybe switched off..that is de only possiblilty that i think maybe the problem..
May 25, 2009 | Sony Ericsson W890i Cellular Phone
Cannot hear incoming calls
phone ring low. how do i turn up the volume?
Jan 04, 2009 | Samsung BlackJack II Smartphone
Nokia 6800 won't ring
go to profiles settings, then select GENERAL........
sexy-ym
Sep 04, 2008 | Cell Phones
Ring voloume
ave you set it from inside the profiles for incoming calls. have you turned up the volume from the side of them phone when making or recieveing calls. set your pofile with all the loud tones and then it should work again.
Jul 20, 2008 | Lands Phones
My phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Jul 15, 2008 | Nokia 1600 Cellular Phone
Ringer doesnt work Nokia 3120
hi follow these instructions
1 menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
once you have done them settings try your phone and see if it works if not then follow these instructions
1. menu
2 settings
3. profiles
4 general then personalise
the set like this
Incoming call alert (ringing)
ringing tone (choose ringtone)
ringing volume (level 5 )
message alert tone (choose tone)
Keypad tones (on)
warning tones (on)
once you have changed the last setting press back then select activate your phone should be now be working if not let me know ok
Mar 21, 2008 | Nokia 3100
Philips CD535 Cordless Phone Logo
23 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
