Question about Kenmore 74602 Gas Dryer
I have a Kenmore Gas Dryer, model 110.73942101. During the start of the drying cycle, the drum spins, I hear the click and the glow plug glows, the second click the gas releases and fires. This will happen the one or two more times and then all that occurs is the glow, but no ignition. If I let the dryer sit fora few hours it works fine for the first two or three firings and then the same, glow but no ignition.
the dr
  • 447 Answers
SOURCE: kenmore gas dryer 80series model 110.c72852101
90% of all gas dryers lighting intermittently is resolved with new coil packs on the gas valve. The coils are replacable fairly easily and inexpensive.
Posted on Oct 04, 2007
  • 1028 Answers
SOURCE: dryer does not dry
change both coils on gas valve(the round black dohickys with wires attached)
Posted on Jul 05, 2008
  • 77 Answers
SOURCE: Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Posted on Apr 18, 2009
protek480
  • 1723 Answers
SOURCE: Whirlpool gas dryer "ultimate Care 2" does not dry my clothes.
yes, the gs coil is not opening. Go to www.repairclinic.com put the model number in and get the gas valve.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Aug 31, 2009
  • 114 Answers
SOURCE: Dryer not drying
First thing to check is the vent. Make sure you have sufficient air flow to the outside. If you are not sure if you have the proper rate of flow, disconnect the vent from the dryer, turn dryer on and see if burner stays on longer. Do this with a couple of damp, spun-dry towels inside the drum. If the burner short cycles again, you need to replace the coils on top of the burner assembly. These are the two black round coils.
Posted on Sep 09, 2009
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
Kenmore gas dryer 80series model 110.c72852101
if you hear the valve clicking but no gas the valve is bad.when the burner lights theres a probe that senses that it is lit and sends a microvoltage back to the controller to tell its lit.check to make sure all ground wires are grounded to a clean metal surface.
Oct 03, 2007 | Kenmore 74602 Gas Dryer
Hi, I have a Kenmore gas dryer model 417. I can't
Sounds like the coils on the gas valve are bad.
May 26, 2011 | Kenmore Dryers
Dryer spins,screen clean,exhaust open blows good no heat
Check the coils on valve or the igniter. Access both thru Access panel on lower right of front panel. Set heated dry cycle & start, igniter should glow bright followed by a "Click" sound, which is valve opening. If it glows and no click, replace the valve coils (2 donut looking objects on top of valve). If no glow, replace igniter, usually just unplug to remove, carefully, they are ceramic and break easy.
Feb 13, 2011 | Maytag MDG2600BWW Gas Dryer
Gas dryer Amana Model LGA30AW, rattling noise, no heat.
I was experiencing a similar problem. I just repaired mine yesterday, with the help of this web site. Remove the front bottom panel. The are two screws located on the bottom of the panel. They are there, just slightly hidden. Turn on dryer to heat. Look inside where the panel was. Wait a minute or two and you will see the igniter glow. After a minute or so you might hear a click and the gas valve will open to start flame. After a while flame will go out until it cycles again. If your igniter glows and you hear the rattling noise and then the igniter glow goes out and you have no flame, it might be your solenoid coils are bad. These are the two black round things located on top of the gas valve. Make sure your gas dryer is unplugged. There is a wire clip attached to each solenoid. Unplug them. I needed to pry them off carefully with a flat screwdriver. There is a metal bracket holding those two solenoids in. There are two screws that you will need to remove the bracket. Use a flashlight to see them. Slide them up and off the gas valve. One is a 2 prong and one is a 3 prong. I bought a new set for 26.75. Put the new ones back the same way as you took them off. The is little nips on the top of the solenoid that line back up with the holes of the top bracket when reassembling them. Plug your machine back in and turn on and watch to see if the ignitor glows again and watch for the flame. Put panel back on and enjoy dry hot clothes again. GOOD LUCK
Aug 09, 2009 | Amana ALG331RAW Gas Dryer
Kenmore 110.74832400 dryer runs but no heat is coming. I removed the back panel from the dryer and I can see the glow from the ignitor but there is no flame. When the dryer is first started the flame is...
the solenoid is going bad on you. there should be two on the bottom by the front of the machine... gotothis site www.techray1.com and click on the guru guy on the left. this will take you to the site where it will sell it to you cheap and installation instructions
Jun 14, 2009 | Bosch Nexxt WTMC3521UC Gas Dryer
My kenmore dryer does heat up all the time.
After the glow plug starts glowing a sensor detects this bright glow and turns on the gas which will be ignited by the glow plug and you have flames.
So, it could be this sensor or in the gas valve solenoids. You will need an OHM meter to check this.
Dec 21, 2008 | Kenmore Elite HE4 Electric Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Kenmore 74602 Gas Dryer Logo
157 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
