Question about Luminox A.0201.BO SENTRY 0200 SERIES
Luminox 0200 stopped working
Changed the battery and it still won't work
I just changed the battery on a Casio watch A158W and now the alarm and hourly chime doesn't work.
The replacement battery may not have been installed properly. It can be a tricky operation. Also, the replacement battery could be ng.
May 31, 2013 | Casio Pathfinder PAG40B-2V wristwatch
Watch won't work after changing battery
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs..
Apr 20, 2013 | Watches
Won't run, it it battery operated?
yes it is battery operated,sudjest you get the battery changed at local jewelers.
Jan 09, 2013 | Fossil JR9413 Watch for Men
Just change the battery on my Nike Anvil WC0020 watch and the alarm won't sound for the timer as well as the two alarm settings.
If you changed battery yourself, you've lost the tiny spring without noticing it. Carefully check around the place where you changed the battery. The spring itself is very, very tiny, so, be as concentrated as much as you can. That spring (coilspring named by watchmakers) transmits the signal from watch movement to the watch back cover where the sound membrane is located. In case if you find it, open the watch and insert that spring with the bent out end first in to the desired hole in watch movement (should be named COIL SPRING). After that re-assemble watch and the sound should work.
Jun 02, 2011 | Nike Mettle Anvil Super Watch Obsidian...
Tag kirium f1 crown does not work, light does not come on for 6 seconds, also buttons do not work
Is the digital display blinking? If it is, it would mean that the battery is weak and thus, the backlight won't work.
Dec 17, 2010 | Tag Heuer Kirium Formula 1 Chronograph...
My watch ar2434 is not functioning properly. the seconds hand moves for some time and then stops. i changed the battery but the problem still persists. what could be the problem?
mcdevito75 here, The quatrz movement could need a little quartz oil or the quartz movement could be going bad, but foirst check make sure you have the correct battery and that it didn:"t work loose Return to whoever changed the battery to have it checked.
Jul 21, 2010 | Watches
Battery changed now watch not working
It sounds as if there is a detector in the watch that registers when the watch has been opened.
Perhaps there is a method of resetting your watch (perhaps known to recognized dealers?).
Read your instructions carefully to see if you can find anything about battery changing. Most makers don't recommend that you change batteries yourself, so I don't hold out much hope on that one.
Otherwise you will have to take it to a recognised dealer in your type of watch.
Feb 02, 2010 | Watches
Changed battery in Movado. Is there a way to reset?
No, there isn't any buttons you are missing.
My first advie is to test battery for full power. If it is, then clean all contacts in battery hatch.
If it still do not work, the gear train can be jammed or the integrated circuit faulty and repairs can be undertaken by skilled watchmaker only.
Dec 03, 2008 | Movado Museum Esperanza 604122 Wrist Watch
Luminox A.0201.BO SENTRY 0200 SERIES Logo
69 people viewed this question
Top Luminox Watches Experts
Ansel Alberto
Ansel Alberto
Dennis Fitzsimmons
Level 1 Expert
Are you a Luminox Watch Expert? Answer questions, earn points and help others
