Question about Dometic Refrigerators
Dometic rm2611 freezer works fine on propane but fridge doesn't cool
Both work fine on ac
    Top Expert:
  • Dometic Master
  • 7,228 Answers
Move temp sensor to middle of coil if same replace temp sensor
Posted on May 27, 2016
  • James Cummings
    James Cummings Sep 22, 2016
    What temp sensor and what coil? Are you referring to the thermistor?
  • 68 Answers
SOURCE: AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Posted on Mar 18, 2009
  • 68 Answers
SOURCE: Dometic Americana Freezer/Fridge not cooling
The recall has nothing to do with your fridge not working. Your cooling unit has gone bad. And yes you can get a new fridge for a few hundred more than a new cooling unit. And sooner or later PPL motorhomes will run out of their cheap stock. The fridges they have are out of production. I know I am a Dometic dealer.
Posted on Mar 19, 2009
  • 9 Answers
SOURCE: My dometic fridge doesn't cool some times but the freezer works
I don't know what type of fridge you have side by side or top mount or bottom mount but what every it is sounds like the air ducts are blocked with ice or the air damper is not working.
Posted on Apr 02, 2009
  • 358 Answers
SOURCE: Dometic rm2611 quit on the road today all lights
If the fridge is complete dead (no lights no fan, no compresor,etc.) looks like there's not power in the unit.Check if theres power in the oulet if you know how , if you don't put the fridge in an oulet that you know is power , if still doing nothing probably the cord is broken or burned and the power doesn't go throught it from the oulet to the fridge.
Posted on Apr 27, 2009
  • 9 Answers
SOURCE: Dometic refridgerator won't stay lit on Propane
A bit more info is needed. What model #, and how old is it? In back, does it have a computer board (underneath a green or black plastic cover, appros 4" x 6")? Im guessing that it does, ('cause you get an error message,) Make sure that you have a good 12 volts going to the board at all times, and make sure that the glass fuses on the board are not blown. If that checks out, than its a real good bet the you have a defective board. For Americana models, you're going to need a Dometic board, and for other models, an aftermarket board will usually do. Althoiugh the OEM ones have a better chance of fixing your problem.
Posted on Jul 26, 2009
My freezer seems to work fine on the AC but the fridge will not get cool any idea what the problem might be Dometic model RM2652
Move your temperature control (slider) down. If it is close to the freezer it does not get the signal that it is warmer.
Sep 18, 2014 | Dometic RM2652 Refrigerator
DOMETIC RV FREEZER WORKS FINE ON PROPANE BUT THE FRIDGE DOES NOT COOL
Give Arcticold a call. We will help diagnose the problem free of charge. I would help on this site but will require a lot more info. Toll free 1-888-782-6665 I have attached a video that may help. 88bf4c61-06e7-40b5-9515-34afd5643a3d.jpg Store
Mar 28, 2014 | Dometic RM2652 Refrigerator
Freezer works fine on propane but not the fridge
You may wish to check the flue clear anything that you find. Old birds next etc. Also make sure the flame and orifice are clean free from debris or rust. Propane should burn blue not orange. Incorrect gas setting if the flame is orange. Some yellow at the tip is ok. Proper adjustments are critical. Have you tried the unit on AC?
Other tips I have read indicate possible freezing in the back.
Defrost freezer completely as some here mentioned and restart see if this helps. Here is a good RV forum I saw good tips worth investigating.
If your not comfortable cleaning the jets and adjusting the flame have a professional do this. Safety comes first!
Freezer works refrigerator doesn iRV2 Forums
RECHARCHING MY DOMETIC RM2611
Hi, it is not as simple as recharging when it comes to an RV fridge. If you have lost your pressure then you need a replacement cooling unit. A Cooling unit can normally be changed in approximately 2 hours with no specialized tools needed. Our cooling units come standard with installation instructions. Arcticold cooling units are Bran NEW not rebuilt. Our Products are unmatched in quality and performance. Check us out
Jan 17, 2014 | Dometic Refrigerators
Dometic rm2611
disconnect thermistor on back let run if ok replace thermistor
Apr 27, 2013 | Dometic Refrigerators
Dometic Fridge Intermittent on 120V
the dometic fridge you mentioned was outsourced by Dometic and they are having problems. (unit 2652) call dometic at 18888674188 and give them your mod and serial number.
May 26, 2012 | Dometic RM2652 Refrigerator
Fridge works on propane but will not cool on electric. unit is a dometic american 10 years old.
Are you familiar with the location of your heating element for 110-120 VAC.
DO you have a multimeter, or AC voltmeter, and know how to use it?
Jun 07, 2010 | Dometic RGE400 Top Freezer Refrigerator
Apr 27, 2009 | Dometic RM2620 Refrigerator
Refrigerators Logo
74 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
