Question about Oregon Scientific RGR126 Rain Gauge with Outdoor Thermometer and 9day Memo
How do you unlock the batter compartment in the rain gauge
Do you pull up or pull out to open battery case?
Are the batteries glued into the battery compartment? If so how do I remove the batteries?
none I have ever seen are glued down .some do have a clamping device .
Jan 17, 2016 | Pride Health & Beauty
Volts problem
the best way to find if you have a short/draw being taken from the battery is to shut off everything in your car open your hood and close your doors in case you have a dome light that comes on when the door is open .Then take and disconnect the ground cable from the battery hook up a test light from the positive post and touch it to the disconnected ground cable if the light comes on you have a short now all you need to do is start pulling fuses until the light goes out then you know on which circuit your short is on.
Mar 22, 2014 | 1982 Chevrolet El Camino
Cannot remove the batter for a recharge
Let me guess? This is the first time you want to remove the batteries, because you can't charge them anymore. And last time you used the camera was months ago?
This looks not good at all. Great chance the batteries in the camera were exhausted and did leak. Or the batteries are exhausted and are swelling, without leaking but are pressing against the battery door. In both cases you have to try to open the battery door and remove the batteries. Sometimes it helps when you press against the door, release it and press again. Little tapping could help also, but be aware cameras are made with delicate electronics and lenses. I hope the batteries did not leak, but is the did, try to remove everything from the battery what is in the battery compartment. Then clean the compartment very well. Special the contact points. But don't use sharp tools or grinding paper, because the contacts will oxidise in a short time again. Just dry cloth, or if you have contact out, little oil and after you cleaned everything rub it dry with a kitchen paper and a dry cloth.
Success.
Buy good NiMH batteries, to replace the ones you remove.
Charge the batteries in an external charger and remove the batteries if you don't ue the camera.
Jan 10, 2014 | Pure Digital Flip Mino Digital Camera
How to load batters in my marksman rl60 lazer
3 D cells. Open the battery compartment, and insert them as indicated on the battery openings.
Dec 10, 2013 | Topcon Rlh3c Rotating Laser Level W...
How do you change the batteries on the Rain Drip R673CT two stage timer
Timer is powered by 2 AAA batteries that are installed in the battery compartment located just below the control buttons on the face of the timer. Squeeze the two tabs, on the front of the battery case, toward each other and pull the battery case out of the body. The + tip of the battery must be pointed away from the spring.
Jun 12, 2011 | Raindrip R673CT Digital Water Timer
Batter drain
check your standing current draw put an amp gauge between the negative battery term and the battery negative post check for current draw anything over 1amp is not good pull the fuses one by one until the fault goes away that will be the faulty part or wiring
Jun 06, 2010 | 1996 Ford Windstar
I left my Sony DSLR our in then .. it didnt rain for a long time. When I finally remembered and went to pick it up it was completely dry .. we didnt turn it on and we took the battery out immediately .....
Hi!
You may keep it turned off until all the external parts and the battery compartments get dry. Furthermore, since the Camera has got wet in rain so there is possibility that rain water may have imbibed inside the Camera thus causing mechanical failure.
So, if the Camera doesn't turn ON even after drying it completely and charging the Battery fully. In that case, service will be required.
Aug 24, 2009 | Sony Cameras
Doesn't recognize new batteries - no photo function
Use a Q-tip with alcohol to clean all the batter contacts (battery cover and inside the battery compartment), and a small hook into the compartment to pull up the contacts a little bit up. The idea is to make the batteries connect properly.
Use NiMh rechargeable batteries or Alkaline batteries, don’t use other Dry batteries, which are not designed for digital camera.
Mar 30, 2009 | Canon PowerShot S2 IS Digital Camera
Nordic ware Belgiam Waffler maker
This is how I use the nordic ware...
1.Heat pan on medium heat on one side until temp gauge is in the middle. Dont turn pan at all when pre-heating
2. Open pan and coat bottom with a little butter.
3. Flip pan over and add butter to bottom side that has no butter.
4. Add batter quickly so butter doent burn. Add semi-thick batter in pan and only let batter run so there is about 1 inch of space left on the edge.(This space will fill with batter when you close the cover)
5. Temperature gauge should stay near the middle at all times.
6. Do not open the pan to check the batter waffle color or your crispy waffle will turn soft
7. Let waffle cook on first side until the steam that comes out from the side slows down to about half of the amount of steam that came out when battle was first put in. (Should be about 2 minutes)
8. Turn waffle pan over and DON’T open the pan.(you haven’t opened the pan once to look)
9. Let cook until steam reduces (Takes about 2 minutes)
10. Keep an eye on the temp gauge
11.Remember the first waffle always takes longer to cook than the second and third waffle.
12. If you have the urge to open the pan. Open the cover slowly. If it doesn’t open up easily then it is still rare and wait one minute to open. If you need to look, you should only open the pan after you turned it over. Once you open the pan, leave it open. If you close it the cripy top will turn soft.
13. Remember trial and error
Mar 16, 2008 | Nordic Ware 15040 Belgian Waffle Maker
Oregon Scientific RGR126 Rain Gauge with Outdoor Thermometer and 9day Memo Logo
37 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Lawrence Oravetz
Timllfixit
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
