Question about KB Gear JamCam 3.0 Digital Camera
How do i clear the pictures off the camera to start over
Its a jamcam3.0 how do i clear the pictures to start over
Re: how do i clear the pictures off the camera to start...
Press the right button on the back till "Clr" flashes,
then press the left button.
Posted on Nov 29, 2007
0 characters
3 Points
Went to florida (hot & humid)recently and my camera started takig some blurry pictures
Clean the lens with a microfiber cloth and let the lens and camera come to ambient temp. This should remove the fog and make your pictures clear again.
Aug 18, 2014 | Kodak EasyShare Digital Cameras
Turn on the camera, the start screen shows up and slowly turns to black. I don't see a thing. I tried to take a picture and check it using card reader, I saw picture I took was very clear on my co
Hello, On the C743 this will require that the LCD unit be replaced. This will get very costly real quick unless you can do it yourself. Not much more I can tell you.
Best Regards, Russell
Dec 22, 2012 | Kodak EasyShare C743 Digital Camera
Fuji finepix s3100has no power even with new batteries
I have this problem also with Fuji Z90 model.
Problem is fixed and focus now working ok.
Camera is fall down and after when camera was started giving sound click click from focus big motor and error on screen Focus error
Focus ( lens ) was open ( small cover on top bellow sticker ) Small "snail" gear is taked out . Two sliding segment adjusted for focus ( upper full up and lower full down - beware about spring inside below this focus pins )and snail is inserted back. Camera started and focus start working. I need to make small adjustment . Reason when camera is started picture is not clear and before using camera i need to do full zoom in and back zoom out. After this picture is crystal clear and all working ok.
Dec 17, 2012 | Fuji FinePix S304 Digital Camera
Hi chicbenzon_1 ,
The LCD picture is clear indicates that the lens is clear enough to capture the image, if there would be any disturbance on the lens you would come to know on the LCD itself.
When you push the button to shoot , it could be that you are pressing the button just half way which is a function used to focus on the object before full press of the button or actual shot of the image.
I would recommend you to half press the button till you focus on your image and then when your hands are steady and there is no shake on the camera , go ahead and press the button full which would result in the image being taken.
Hope this helps ...:)
May 11, 2011 | Olympus FE-320 Digital Camera
I am having issues with my camera taking unclear pictures. my screen appears clear when going to take the picture, although after taking the picture and it showing it to me. the picture appears unclear and...
Please check : - Battery ( replace with new one and fully charged ) - If it is not help, you have problem with parts inside camera ( usually an IC) and need to repair at shop or dealer.
Dec 22, 2010 | Canon PowerShot A470 Digital Camera
Camera timer factor; wish to clear settings
Make sure you have the dial set on 'P' not green suare, then when you go to Clear settings, go up to the clear all cameras ettings, and that will res\et camera for you. Failing that, just turn the delay timmer off with the circular button 2nd from top, LHS of the LCD.
Jun 08, 2010 | Canon Rebel XT / EOS 350D Digital Camera
I have a Sony-Cyber shot DSC-P72
It's a memory card error,You can try to take the memory out and retrieving them with your computer
May 13, 2009 | Sony Cyber-Shot DSC-P72 Digital Camera
Select a picture (pres rev button)
Then press the Del button twice.
The display gives you the option to delete all the pictures or multiple pictures.
Apr 22, 2008 | Panasonic Lumix DMC-LZ5 Digital Camera
The picture taken is not clearly visible,nor its clearly visible in the folder,
This sounds like it might be a defective CCD imager. If so, Sony should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
Applicable cameras include:
Cyber-shot DSC-F717, F88, P10, M1, P12, P2, P31, P32, P51, P52, P7, P71, P72, P8, P92, T1, T11, T3, T33, U10, U20, U30, U40, U50, U60, V1
CD Mavica MVC-CD250, CD400, CD500, and FD Mavica MVC-FD100, FD200
May 01, 2007 | Sony Cyber-Shot DSC-T3 Digital Camera
KB Gear JamCam 3.0 Digital Camera Logo
75 people viewed this question
Top KB Gear Digital Cameras Experts
Are you a KB Gear Digital Camera Expert? Answer questions, earn points and help others
