Question about RCA RS2601 CD Shelf System
Have hooked the speaker wires to the unit but cannot find where they hook to the speakers
Speaker hookup from radio to speakers
techman
  • 3130 Answers
SOURCE: Problem adding wsp155 wireless speakers.
You must check with the instalation gude for the wireless speaker to see if the connection to the reciver is a high impedence or low impedence... If its like most wireless set-ups its going to be a high impedence output from the reciver to the transmitter part of the speakers. That would be from the RCA jacks in the back of the reciver maked line out or tape out. If you want to use them for a specific speaker output , some recivers have an output jack that would be labeled center sperker out but would be an RCA type jack ect ect. If your reciver dosent have that you can in a higher end audio store get an adaptor to convert the speaker output to a high impedence, But I dont recomend that as some of the adaptors do cause excessive strain on the output section of the amp or reciver.. If you buy a good one though you should be fine.. You get what you pay for.. Good Luck
Posted on Aug 06, 2006
  • 99 Answers
SOURCE: Can I hook up external speakers to this T.V.?
This tv carries two sound out phono plugs, but if for some reason they are not there ( date of mfr ) you can use the headphone out jack. Just go to any radio shack store and explain what you are trying to do and im sure they will be happy to assist you.
good luck,
Posted on Feb 09, 2008
jfpogie
  • 104 Answers
SOURCE: power but no sound
good day, here is a link to the manual. Hope it helps!
http://support.radioshack.com/support_audio/doc61/61791.pdf. thanks
Posted on Feb 17, 2008
SOURCE: UNIT HAS ALL POWER FUNCTIONS BUT OUTPUTS NO SOUND.
This comes to mind:
Did you perhaps connect the rca jacks to the record in instead of the play out?
Maybe the rca cable is not plugged in at all on either the receiver end or tape deck end.
Have you tried using a different rca cable?
Did you select the right input on the receiver?
You may try using a different input on the receiver.
I know these sound obvious, but they may fix the problem.
Posted on Oct 10, 2009
SOURCE: Rear speakers not working
RCA rt2500 AV main & surround inputs are not working. I plugged the speakers into the subwof and center sk. inputs. The speakers worked. Is there a fuse I can repalce?
Posted on Oct 24, 2009
How do you hook up a subwoofer or a speaker box to factory stereo
Some radios on newer radios have RCA plugs tucked up in the wire harness to easily connect a sub amp. The sub amp you select will have the necessary instructions for hookup
Jan 22, 2017 | AMP Car Audio & Video
RCA & speaker hook up
I need code for : Blaupunkt GMBH 7 612 001 015, BNO 881. Made in Germany. Radio navigation AU Z1Z1B6079922
Thanks. my e-mail: max_zoki@hotmail.com
Best Regards.
Jul 15, 2013 | Car Audio & Video
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
Radio display says protect. does not emit sound.
Sounds like you have either a short in your speaker wire somewhere, wires touching in the back of the unit or a short inside the stereo itself... Try pulling the radio out and unhooking all of your speakers...Turn unit back on after all speakers are disconected...If unit still shows protect, then radio is bad...If it doesnt, power off and hook up speakers one by one and power it back on till it shows protect again....When it does, the last speaker wire you hooked up has either a crossed wire or the speaker is bad...
Oct 07, 2010 | Kenwood KDC-MP205 CD Player
Stereo Wiring Colours
2006 Ford Focus Car Stereo Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Yellow/Green
Car Radio Accessory Switched 12v+ Wire: Orange/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
Jul 11, 2010 | 2006 Ford Focus
Receiver unit shuts off when there is a sudden change in sound and bass, ex: when a car explodes on a movie it shuts off.
Sometimes this is due to clipping, the receiver will shut off to protect itself or the speakers. Check all your wiring to your speakers and at your receiver hookup, If you have a subwoofer hooked up to it? Check to see if the wiring is hooked up ok and ensure there is no shorts. Hope this helps,
Turk
Oct 21, 2009 | Audio Players & Recorders
No sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Feb 16, 2009 | Sony CDX-CA700X CD Player
Jensen vm9411 has no sound from radio hookups put rca wires have sound
If the previous radio played all the speakers and the new one wont either:
1. You have not hooked the speakers up right.
2. All your speakers are blown.
3. There is a factory amp, you just don't know about it.
4. The radio has blown final outputs.
5. One or more speakers or speaker wires is seeing a ground (shorted out)
First check the radio, hook up a know good test speaker directly to the speaker outputs on the radio. If it works, then take a 9volt battery and try to pop the inside speakers with it. When you touch the + & - speaker wires to the battery + &- you should hear a pop at the speaker. If you do you don't have an amp. If you don't you might have an amp or the wire going to the speaker is dead or shorted out. It is unlikely that all four speakers would be bad or have bad wires. If none of them will pop you need to turn on the factory amp. Then they will play. If only one speaker wont pop then that is the bad speaker. If they all pop then you have a bad speaker or wire.
Dec 18, 2008 | Car Audio & Video
Adcom GFA-5400 installation
Use the niles for more than one speaker hookup. As far as the sub hookup, use a powered sub with speaker inputs
then use the right or left speaker and tag a couple wires to the sub. Good Luck
BIGRED
Dec 28, 2007 | Adcom GFA-5400 2-Channel Amplifier
RCA RS2601 CD Shelf System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
