Question about American Standard 5 ft Sliding Shower Door
Shower door's mirror like surface has peeled off the shower door, looks bad anything I can do?
The mirror like surface on the shower door has started coming off and looks bad, is there anything I can do, short of totally replacing the shower door?
Can you please give me the e mail address to contact Niagara as you suggest in your answer to my question as I can't find one but assume there is one as you recommended it. Thanks.
Hello Irene
You need to make this request in the original post under Tom's reply to you. You will see the word COMMENT, click on that and Tom will get a notification that you require further help. Fixya gets 9 million posts a year so the chances of someone seeing it as slim to none.
I am thinking one of these links will help you though.
Meynell Niagara (Niagara) shower spares and parts ' Meynell Niagara ...
https://www.showerspares.com/meynell_shower_spares/.../meynell_niagara_niagara/
  1. Cached
  2. Similar
Buy Meynell Niagara shower spares online. All shower spare parts for the Meynell Niagara in stock with same day despatch from the UK's #1 shower spares ...
Meynell Niagara 2 (Niagara 2) shower spares and parts ' Meynell ...
https://www.showerspares.com/...shower_spares/...all/meynell_niagara_2_niagara_2/
  1. Cached
... Niagara 2 shower spares online. All shower spare parts for the Meynell Niagara 2 in stock with same day despatch from the UK's #1 shower spares retailer.
Glass Inc,Niagara Falls,Glass,Showers Stalls,Shower Doors,Home
www.glassinc.ca/
  1. Cached
  2. Similar
Niagara Falls, Ontario, frameless shower enclosures, frameless shower doors, shower stalls, mirror, backsplashes, back painted glass, St. Catharines, Home.
Shower doors, bath screens - Niagara System Ltd.
www.niagara-wellness.com/productcategory/shower.../shower-doors-bath-screens/
  1. Cached
  2. Similar
Home/Shower enclosures/Shower doors, bath screens. Showing all 6 results. Default sorting, Sort by popularity, Sort by average rating, Sort by newness, Sort by ...
Here is the link to your post.
My Niagara bifold shower door fixtures are broken Is the Niagara company...
Oct 30, 2016 | Computers & Internet
How do you clean hard water spots on shower doors?
I would buy white vinegar, and an inexpensive empty spray bottle e.g. from WalMart. Fill the bottle with vinegar, spray the doors lavishly, let them soak the liquid up, wipe them down. Then repeat, wiping doors with paper towels until you get a shine. Also, once you have the doors clean, wipe them down with a cheap shampoo each time you shower and rinse. Seems like this would keep them shiny.
This is assuming that your doors aren't extremely bad with hard water spots. It may still work well.
May 07, 2012 | Home
Where can I find shower door rollers for a maax shower door? Thanks.
amazon is one of the best places for purchasing your shower door rollers. Click here Amazon com shower door rollers and choose the best one (many of them are compatible with maax shower door), but anyway, before order something contact the seller to be sure. There's a plenty of rollers, so take a look.
I hope this was helpful.
enjoy
Mar 05, 2011 | Home
A small worn area on mirrored door in my shower, can it be repaired?
Yes but it will be expensive
A glass shop can re-apply the silver coating on the back surface of mirrors
Apr 02, 2010 | Home
Need to replace drip cap on bottom of door
o.k. these are usually attached with a double sided tape,...you need to get something like a scraper or the like and get in between it and the door,..go slow and pry it off,...SLOWLY! once you get the old one off, you'll need to clean surfaces with a rag and rubbing alcohol,....(very important for new one to stick),.....take your time with this operation,..it doesn't look like much but trust me, i've worked on many shower doors and patience IS your best friend,....again, go slow and pay attention to ALL details.
Sep 28, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Leaking Microwave door seal (between grated and back of door)
I think that you can get the plastic wet, ie sponge, or lick.
Jun 26, 2009 | Microwave Ovens
I need to replace the drivers side mirror on a ford explorer 2000....how is this done? I know you take it off, but does the inside door panel come off?
you remove door trim panel and the plastic water shield .disconnect electrical connectors from the mirror.peel back insulator pad .then remove the mirrors 3 retaining nuts remove the mirror.
Apr 24, 2009 | 2000 Ford Explorer
Changing Door Mirror Glass XJ6(X300)
Hi
You need to put on a pair of gloves, and safety glasses. (Safety First !)
Prise off the broken mirror from the plastic base that it is stuck too.
Give the plastic a clean with nail polish remover or similar.
Peel off the backing on new mirror glass, and carefully stick it on.
Good Luck !
Don´t forget to FixYa Rate Me Please !
John.
Feb 05, 2009 | 1998 Jaguar XK8
American Standard 5 ft Sliding Shower Door Logo
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
