Question about Linksys Wireless-G WRT54G Router
What is default userid & pasword after login in to linksys menu
  • 30 Answers
You can find it here:
http://cirt.net/passwords?vendor=linksys
posted by cj-skynet
Posted on Jun 15, 2009
What is the default user name and password
Default userid is "linksys".
Default password is "admin".
Dec 02, 2013 | Linksys WRT120N Router
How to change pasword the lingskys router
I never heard for LingSkys router. I will explain for LinkSys router. It must be something similar.
In your browser type http://192.168.1.1
It is default IP address for lot of routers (it can be changed too).
When login screen comes, default is only password word: 'admin' (name is blank).
You can always reset router with 10 second of pressing reset button to this default option.
You can going to Administration where you can find password input. You must Save configuration too.
Lot of router has easy default password like 0000, 1234, admin...
It must be something similar for your router. Is it right name for router? I can't find this name in Google...
Aug 26, 2011 | Computers & Internet
Another business we share an office with wants to use our photocopier. How do we set up their own password to enable this to work.
You can always find solutions to Xerox problems @ www.xerox.com/support Once you set this up both you and your neighboring business will BOTH have to use individual codes. Hope it helps!
Solutions for : How To Set up or Modify Auditron User Accounts Solution : Set up or Modify Auditron User Accounts The following information describes how to register userIDs and usernames, login names, and passwords for authenticating accesses attempted through the network for scanning services, and impose restrictions on the maximum number of pages to be copied or scanned. Up to 500 user accounts can be registered.
NOTE: You must be a System Administrator to perform this solution.
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
  5. Select [System Settings]. The System Settings screen will be displayed.
  6. Select [Login / Auditron Administration]. The Login Setup / Auditron Administration screen will be displayed.
  7. Select [Create / Check User Accounts]. The Create / Check User Accounts screen will be displayed.
  8. Select a user account number or use the numeric keypad to enter a user account number in the Go to (001-500) field.
  9. Select [Create / Delete]. The User Account screen will be displayed.
  10. Enter a userID using the keypad on the Touch Screen, and then select [Save]. The Create / Delete screen will be displayed.
  11. Select from the following options:
    • UserID: Allows a userID to be entered using the keyboard on the Touch Screen. Up to 32 alphanumeric characters can be entered including spaces.
    • User Name: Allows a username to be entered using the keyboard on the Touch Screen. Up to 32 alphanumeric characters can be entered including spaces.
    • Password: Allows a password to be entered using the keyboard on the Touch Screen. 4 to 12 alphanumeric characters can be entered. The Password button is also displayed if a password was selected on the Login Setup / Auditron Mode screen.
    • Remote Login Settings: The following settings can be modified on this screen:
      • Login Name - Allows a login name to be programmed that needs to be entered when the machine is accessed through the network.
      • Password - Allows a password to be programmed that needs to be entered when the machine is accessed through the network.
    • Account Limit: Select [Copy Service] or [Scan Service], and then select [Account Limit]. Using the numeric keypad on the Control Panel, specify and restrict the maximum number of pages to be copied or scanned for the account. The maximum number can be entered within the range of 1-9,999,999 pages.
    • Reset Total Impressions: Deletes all data tracked for the selected account.
    • Reset Account: Clears all settings and data for the selected account.
  12. Select [Save].
  13. Select [Close] three times.
  14. Select [Exit].
Feb 03, 2011 | Xerox CopyCentre C123 Copier Copier
How do i change the number of rings for xerox workcenter 123 to pick up for receiving fax
  5. Select [System Settings] twice. The System Settings screen will be displayed.
  6. Select [Fax Mode Settings]. The Fax Mode Settings screen will be displayed.
  7. Select [Fax Defaults]. The Fax Defaults screen will be displayed
You wll then see locations to set the amount of rings to answer, ECM mode etc.
Jul 23, 2010 | Xerox WorkCentre M128 Copier
Not sure of my WEP key on my BEFSR41 linksys router
The only way to see your WEP key is to remote into the router. Open a browser window, enter 192.168.1.1 in the address line and hit enter. When asked to login the default login is:
UserID: admin
Password: (nothing - as in do not enter anything)
IF this has not been changed and you get in, click on the wireless tab and you should find your wireless key there.
Good luck
Apr 10, 2009 | Linksys EtherFast Cable/DSL Router
How do I login to configure
Connect to the router with a cable, open a browser and enter:
192.168.1.1
That will get you to the admin screen for the router. Typical login is:
UserID: admin
Password: [blank] as in dont enter anything
Apr 10, 2009 | Linksys Wireless-G WRT54G Router
Access authorization code
I think this is the one you want to change. If not let me know please.
  6. Select [System Administrator Settings]. The System Administrator Settings screen will be displayed.
  7. Select [System Administrator Login ID]. The System Administrator Login ID screen will be displayed.
  8. Select [On].
  9. Enter a new System Administrator userID in the field provided using the numeric keypad, or select [Keyboard] to use the Touch Screen keyboard.
  10. Select [Next] and re-enter the System Administrator userID in the field provided.
  11. Select [Save] to save the changes.
  12. Select [System Administrator Password]. The System Administrator Password screen will be displayed.
  13. Enter a new System Administrator password in the field provided using the numeric keypad, or select [Keyboard] to use the Touch Screen keyboard.
  14. Select [Next] and re-enter the System Administrator password in the field provided.
  15. Select [Save] to save the password.
  16. Select [Close] three times.
  17. Select [Exit].
    NOTE: Make note of the new System Administrator userID and password. If the new System Administrator userID and password are forgotten, a service call must be placed
Jan 29, 2009 | Xerox CopyCentre C123 Copier
I need to change the access code as some non authorized people are using my photocopier. How can I do that?
I am answering this twice since it appeared twice, If this isnt the code you want to change let me know. I believe this is the one you are asking.
  8. Select [On].
  17. Select [Exit].
Need to establish PIN/Code for machine - help xerox c123
  12. Select [Save].
  14. Select [Exit].
Jan 08, 2009 | Xerox CopyCentre C123 Copier
Linksys Wireless-G WRT54G Router Logo
139 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
