Question about Cuisinart CPT-180 Metal Classic 4-Slice Toaster
Magnets will not ingage
Will not stay down
  • 5 Answers
I repaired the same symtom that happend to one of the sides of my CPT-180 toaster. The magnets wouldn't engage due to a bad C1 capacitor on the circuit board that controlled that side of the toaster--the capacitor was bulged out on the bottom and turned out to be bad. I've attached some photos showing C1 bulged out compared to C1 on the good board.
C1 is the main power supply capacitor and if it goes bad, the circuit board power supply won't function correctly. This can lead to a broad spectrum of problems like the lever not staying down due to the magnets not engaging or the toasting control/timing circuits malfunctioning. If you replace the capacitor, it is best in most cases to replace with the same value as the orginal (220uf on my toaster)---you can usually get a replacement capacitor at Fry's Electronics. Replacing with a higher capacitance may be acceptable, but you should understand the impact to the rest of the circuit before you substitute a higher capacitance value. The voltage rating and temperature rating of the replacement capacitor should be the same or greater or the capacitor will fail quickly. Note the max temperature rating of capacitor C1 is +105C---toasters get hot (duh!) and the temperature around the circuit board of this model gets quite warm, so the temperature rating of the capacitor is critical. Finally, make sure the substitute capacitor fits when installed (requires soldering) and does not interfere with surrounding circuitry or other toaster mechanics when the circuit board is put back in place.
Pictures:
C1_location (next to screw)
Comparing_good_C1_with_bad_C1--note bulge on bottom of right C1
Right_orginal_C1_and_left_replacement_C1
Bad_C1 showing capacitance, voltage and max temperature ratings
magnets will not ingage - 5487aa4b-7e7d-4e6f-9542-cf9ff618008c.jpge1a82299-a243-46e1-b11b-4c20e0d9b304.jpg5543b7e5-8108-4b1d-bed3-90eee4600722.jpg
Posted on May 30, 2014
  • Dale Anderson
    Dale Anderson Nov 17, 2014
    Use a #2 Phillips Head screwdriver to remove the 4 screws from the bottom of the toaster--DA
Hi Dale Anderson,
I have a similar problem with my Cuisinart cpt-180, but can't find the right screwdriver to open-up the toaster. The 4 screws seem to be of a very unusual type.
Can you please advise me what type to use.
Rolf
grtkrayenhoff at hotmail dot com
Posted on Nov 10, 2014
Tip
Flashing Light Error on Tasimo Coffeemaker
That blinking error light! I still could not fix it with the other solutions.
I cleaned it, refilled it, and nothing worked.
Here is what I have done that made it work.
There is a floating magnet in the water reservoir. When it drops down,
the error light is SUPPOSED to come on.
I found by jamming a scrap piece of clean plastic in the magnet cavity on the water side of the magnet. This forces the magnet to stay in the up position AND against the sensor contained in the machine itself. NOW the error STAYS OFF. Hurray! So far, it works!
Note: You must monitor the water level under this new circumstance because the error light will not come on even if the water level drops down.
RW
on Sep 28, 2010 | Braun Tassimo Coffee Maker
Why won't the switch on my 2084 cub cadet stay ingaged
Your battery may be low. Check water level and charger often is power is low the electro magnet will let go. Holding switch could cause too much power and burn out coils on magnet.
Jul 18, 2014 | Cub Cadet Garden
My 87 jeep starter stays ingaged when I try to start it
needs shimmed or the bendix is bad in the starter and not allowing to release. most likely just needs shimmed if it's a new starter, however you can get a bad starter (new or rebuilt)
Aug 28, 2012 | 1987 Jeep Cherokee
Put car in reverse after car warms and it doesnt ingage until you push on the gas. It stays in the nuetral position
hi sound like the clutch is worn and your having to use the speed of the engine to help you ingage the gear.Does the clutch slip at all when driving in a forward gear ?
Sep 02, 2010 | 1993 Saturn SC2
Ac compressor does not stay ingaged
sounds to be just low on freon fill it too the specified amount and this should take care of it,just be carefull not too over charge the system
May 11, 2009 | 2001 Lincoln Town Car
The digital control panel is on the fritz,
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down--and none of the buttons were functional.
My husband took the cover off and found that a magnet is what keeps the lever down when the toaster's on, and allows it to go back up when the toasting is done. It's an electro magnet that works only when the toaster is on. It seems that when I turned the unit upside down and rightside up again, crumbs landed on the magnet's contact plates (which are about 1/4" x 1/2") and would not allow the magnet to engage. Because the magnet wouldn't engage, the lever would not stay down, and the toaster shut off. Brush off the magnets, replace the cover and toast away!
Nov 28, 2008 | Oster 6330 4-Slice Toaster
Bread won't toast
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down.
Dec 27, 2007 | Kitchen Appliances - Others
Cuisinart CPT-180 Metal Classic 4-Slice Toaster Logo
359 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
