Question about Namco Atari Classics 10 In 1 TV Games
Doesn't come on when I plug in the connectors
I have an insignia tv about 5 yrs old
Need help getting Insignia tv to turn on
Your TV has a failed circuit board, which one will require diagnostic testing. Unless you are skilled in TV repair yes I suggest you replace the TV.
Feb 09, 2017 | Insignia Televison & Video
Direct Tv mini caused my Insignia tv to freeze and now tv wont turn back on
The direct mini did not freeze the tv. It's a coincidence. Your TV needs repair. Unfortunately insignia tvs have a reputation for problems like this.
Aug 13, 2016 | Insignia Televison & Video
Fix lcd tv
You need to dertermine if the power board failing charred the connectors, or if a differeb=nt component failed which charred the connectors and took out the power board. This will require component level testing. i suggest taking it in to the repair shop.
However, i would price shop a comparable replacement TV before fixing a 4 year old Insignia. it may be more cost effective to just replace it.
Jan 29, 2015 | Insignia 46 Class LCD 1080p 60Hz HDTV
Insignia lcd tv model ns-ltdvd26 has sound but no picture,and appears to trip a circuit breaker after a couple minutes.this tv is 3 yrs old
the pic attached is an electrolytic capacitor, they come in different sizes and are usually blue, black and sometimes yellow. depending on manufacture.
most of the problems I have heard of tvs having problems with the electrolytic capacitors going bad. if you open the tv and see one of those swollen or leaking you need to replace them.
Feb 13, 2010 | Insignia LCDTV26 26 in. Television
Lines on tv screen
This is a problem with a aging of the television tuner section of the television. the line you are seeing are noise lines on the scan rate. This could be minor component aging and failure. Or it could be problems with the television tuner itself. Loss of tolerances.The problem should be looked at by a service center where they will have all the service information to work on the television. You can call Insignia customer support at this telephone number 1-877-467-4289. Or visit the customer support section on their website. www.insignia-products.com. Give them the model number of the television and they should be able to tell you where to take or ship your television for servicing. I hope this information helps you with your problem.
May 19, 2009 | Insignia IS-LCDTV32 32 in. Television
INSIGNIA 32 IN FLATSCREEN MODEL NS 32LCD
check for capacitors on the power supply that are puffed up. Also the mai board can cause this but the power supply is where i would start.
Jan 08, 2009 | Televison & Video
No signal
I had a similar problem. I then noticed that my antenna has a RG6 cable. This is good. My TV requires RG6 and requires TV(RF) cable that is also RG6. Insignia comes with a TV(RF) cable that is RG59! That's a cable with a smaller diameter center connector than RG6. Consequently, when that smaller RG59 was run from the converter box to the TV's larger RG6 female connector, no signal connection was completed since the center connector made no physical contact with the TV's female connector. I found a RG6 cable to replace the RG59 cable supplied with converter box and all worked then. Also, you must force the antenna's RG6 male plug into the smaller RG59 female connector, but it'll make it.
May 25, 2008 | Insignia Digital-to-Analog Converter for...
HD TV INSIGNIA
Hi Walter, have you checked all your av cables are pushed in fully?
Feb 19, 2008 | Insignia IS-LCDTV32 32 in. Television
Namco Atari Classics 10 In 1 TV Games Logo
26 people viewed this question
Top Namco Video Game Consoles & Games Experts
Jim Goldsmith
Jim Goldsmith
Tom Chichester
Are you a Namco Video Game Console and Game Expert? Answer questions, earn points and help others
