Question about Crosley CE35100AA Electric Kitchen Range
Crosley Dryer error code E64
Dryer starts heat up and shuts off displaying an error core E64.
4 Suggested Answers
Jimster
  • 240 Answers
SOURCE: Crosley Dryer Heats then stops
If im thinking right, this dryer has the element in the top left corner.  This unit has two thermostats, one mounted right above the element, and the other in the lower left front mounted on the fan housing.  The one in the front is called the high limit thermostat, which means when it gets to a preset high temp, it cuts off the system until cooling occurs.  The top thermostat, mounted above the element is the operating thermostat.  It probably is one of the two thermostats.  Its a very good idea to replace not only both of the thermostats, but the fuse as well.  The fuse kit (Maytag Part# LA-1053) comes with a thermostat and 2 fuses, be sure to follow he instructions on how to determine the fuse for electric and gas.  The high limit thermostat (Maytag Part# 53-0771) is an easy replacement.  Something is causing the unit to short cycle.  Sometimes you can hot-wire the operating thermostat (use caution, severe caution if doing this, not recommended if you arent sure whats going on).  By doing this (removing the two wires from the thermostat, taping them together), you can watch and see if the element stays on longer, at least until the high limit switch comes on.  This is really not recommended, if the high limit is out, it will not be good.  Just easier to replace them both.
Posted on Oct 25, 2007
  • 91 Answers
SOURCE: Crosley Electric dryer stopped in mid cycle and will not start
if the machine is completly dead an not doing anything locate your fuse panel ,check your fuses for the dryer ,if you can find wich one is it reset the breakers again you probably popped one of the 2 lines since you need 2 for a 220v.
good luck!
Posted on May 27, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Crosley CDE 7000 dryer that stopped heating
There can be a few reasons why an electric dryer does not heat...
Check out this tip that I wrote... it will help you find the thing that is causing your problem..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 06, 2010
Why does my frigidaire dryer run briefly then stop and show a code of E64
Hello Robert, I appreciate your post!
Based off the information you have provided your Frigidaire dryer is displaying an error code of "E64". An "E64" error code means that the heater has an open circuit this could be an issue with your heater, wiring harness, or a miscommunication within your control panel. To help clear out any miscommunications I would suggest performing a reset. You can reset the dryer by disconnecting power from it for at least ten minutes. If the reset does not help clear out the error code, you may need to seek assistance from a professional technician. This will help you avoid any unnecessary part purchases. I hope that this information is helpful to some degree. -Matt
Feb 16, 2016 | Frigidaire Dryers
My Frigidaire Dryer (Model #FASE7073LW0) has an "E64" message listed. What error is this in reference too?
Good Morning Yasmin Abdullah, I am happy to assist you!
Based off the information you have provided your Frigidaire dryer is displaying error code "E64". "E63" typically stands for heater open circuit, which means that it could be a faulty wiring harness or heater. I would suggest performing a reset on your dryer by disconnecting power from it for ten minutes. This could be a false error code or a miscommunication within the board and a reset will help to clear that out. I hope this information is helpful to some degree. -Matt
Dec 16, 2014 | Frigidaire Dryers
What is an e64 error code on electrolux dryer ewmed70jss?
Good Afternoon Friend,
I understand you are receiving an E64 code on your Electrolux dryer, model# EWMED70JSS, and want to know what it means. What this is stating is that there could be a possible issue either with the heating element or some wiring. It could also be a possible false error code. I suggest resetting your dryer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Electrolux Dryers
My frigidaire dryer is showing an e64 error code dryer works sometimes ?
The unit is displaying this code because the heater's circuit is open. A professional is needed to check the heater coils and connections for any open circuits. Replace the heater and/or wiring connected and then retest.
Dec 18, 2012 | Frigidaire Dryers
We are getting an error code 64. What do we do to fix this
Error code E64 means heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and cancel. Hope this helped Tim
May 29, 2011 | Electrolux EIED55H Dryer
Getting a fault/error code E 64
Error code E64 means heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and ?cancel?
Nov 22, 2010 | Electrolux EIED55H Dryer
I was drying and the dryer shut off and gave an error message of E64
Hi
Error code E64 means Heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and “cancel” buttons simultaneously for 3 seconds. If the error appears again then you’ll need to check heater coils and connections for open circuits. Use a multimeter to check the heater element, use Rx100 setting on the multimeter. It should display 30-33 K ohms as the resistance. If it is less than this or exceeds this limit then the element has gone bad and you would need to replace the element. Hope this helps...
Daniel
Sep 13, 2010 | Electrolux EIED55H Dryer
Crosley CE35100AA Electric Kitchen Range Logo
206 people viewed this question
Top Crosley Kitchen Ranges Experts
Rob
Rob
Level 1 Expert
freddyfox
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
