Question about NCH Software PhotoPad Image Editor
KEY CODE PHOTOPAD
1045-1085-4328-3250-0779-4665
I what to know how to input simulation program to clear maintanance code CA on Mx2610 sharp copier
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Feb 10, 2016 | Sharp Office Equipment & Supplies
How do clear H4 error code on Sharp Copier arm256
OR
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY.
Aug 02, 2015 | Sharp Office Equipment & Supplies
How can i clear H 4 error code on my sharp AR-153E coppier. your help please.
OR
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
Mar 20, 2015 | Sharp Office Equipment & Supplies
How do i fix a h4-01 error code on my sharp ar m277 copier
OR
Feb 26, 2015 | Sharp Office Equipment & Supplies
How to activate simulation mode mx-m264n
OR
When the
Aug 25, 2014 | Sharp M264N Copy Machine
Request specific code or codes to program the RCA Universal Remote RCRN03BR to operate JVC DVD/VCR type HR-XVC33U. The codes provided in the remotes instructions provide only partial functionality on the...
Found some quick solutions including the manual for you
first here is the link for hte code list and manual http://www.rcaaudiovideo.com/remotes/2-3-devices/?sku=RCRN03BR
which i got from various sites after researching your problem for about 30 minutes please let me know if this works i hope i helped i tried really hard
if that doesnt work try these methods PLEASE LET ME KNOW IF I HELPED
for this first method you need the direct code which is 04
  1. Manually turn on the component you want the remote to control.
  2. Locate the Brand Codes in the Code Lists.
  3. Press and hold the component key you wish to program. The illuminated ON·OFF key turns on and remains on.
  4. While holding the component key down, press and hold the ON·OFF key. The illuminated ON·OFF key turns off.
  5. After holding both keys down for three seconds, the illuminated ON·OFF key turns back on.
  6. Release both keys. The illuminated ON·OFF key remains on.
  7. Refer to the Brand Codes. Press and release the appropriate brand code key (Numbers 0-9), using the number keys. The illuminated ON·OFF key blinks once.
    • Note: If you do not press a valid Brand Code Search key, the illuminated ON·OFF key blinks four times and turns off. The last programmed code under that component key is retained.
  8. Press and release the ON·OFF key repeatedly until your component turns off. Each time you press the ON·OFF key, the illuminated ON·OFF key blinks, and the next code is sent. The Brand Code Search begins with the first code in the chosen brand list for that component and cycles through all the codes for that brand. If your component turns off, you have found the correct code. (If it cycles through and the illuminated ON·OFF key blinks four times and turns off, all codes in the chosen brand list have been searched and another programming method should be tried. The Brand Code Search mode is exited.)
  9. Once you have found the correct code, save that code by pressing and releasing the STOP key. The illuminated ON·OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
  10. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your component do not work, program the remote with a different programming method.
if not try this for auto code search
STEP :
  2. Press and hold the component key you wish to program. The illuminated ON·OFF key turns on and remains on.
  3. While holding the component key down, press and hold the ON·OFF key. The illuminated ON·OFF key turns off.
  4. After holding down both keys for three seconds, the illuminated ON·OFF key turns back on.
  5. Release both keys. The illuminated ON·OFF key remains on.
  6. Note: If you press an invalid key during Auto Code Search, the illuminated ON·OFF key blinks four times and turns off. The last programmed code under that component key is retained.
  7. Press and release the PLAY key, then wait five seconds to see if your component turns off. If your component does not respond, continue to press the PLAY key every five seconds until your component turns off. Each time you press the PLAY key, the illuminated ON·OFF key blinks ten times and a block
    of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. (If your component has not turned off after all codes have been searched, the illuminated ON·OFF key blinks four times and turns off. The Auto Code Search Entry method is exited.)
  8. When your component turns off, you know the correct code is in the last block of 10 codes sent. Press and release the REVERSE key. Wait two seconds to see if your component turns on again. If your component does not respond, continue to press the REVERSE key every two seconds until your component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE key is pressed, the illuminated ON·OFF key blinks.
    • Note: If you accidentally press the REVERSE key after your component responds, press and release the FORWARD key. Then, wait two seconds to see if your component turns off again.
  9. Once your component turns on, you have found the correct code. Save the new code by pressing and releasing the STOP key. The illuminated ON·OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
  10. When you press the STOP key, the code is stored.
Mar 16, 2011 | RCA RCRN03BR Remote Control
How do i rectify error code h4-01?
first you have to enter simulation mode:
#/P key (program) ON ? Asterisk (*) key ON ? CLEAR key ON ?
Asterisk (*) key ON ? Ready for input of a main code of simulation
2) Entering a main code with the 10-key ? START key ON
3) Entering a sub code with the 10-key ? START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key to start the simulation operation.
main code is 14, sub code is 0 in your case.
H4-01 means Sub heater lamp abnormally low temperature detection.
You may also have a dirty/defective thermistor in the fuser unit.
Oct 29, 2010 | Sharp AR-M237 Digital Copier
Code for501a area
LATEST KEYS ALL AREAS
EX C&W KEYS -- KEYROLL 30/11/2008
PROVIDER CODE: 5C 01
KEY 00 = 2F 1E 90 1B EA 7F A0 26
KEY 01 = 60 1F 48 73 19 D6 CA 99
TELEWEST KEYS -- KEYROLL 30/11/2008
PROVIDER CODE: 5A 01
KEY 00 = 3F 32 37 03 D0 73 84 84
KEY 01 = C6 64 1D EF 47 5A 0E EF
PURE NTL KEYS (UK) -- KEYROLL 30/11/2008
PROVIDER CODE: 54 01
KEY 00 = 5A 35 D6 3B 4D A0 75 EC
KEY 01 = 28 98 21 38 22 BC B9 EF
IRELAND CHORUS KEYS -- KEYROLL 29/06/2008
PROVIDER CODE: 5E 01
KEY 00 = 51 0F 32 A7 D9 34 BE 3E
KEY 01 = 8D A3 88 1B 4E 32 C5 8F
Nov 30, 2008 | StarTech.com StarView SV211K 2-port KVM...
Eurovox maxv codes in bradford thanx
EX C&W KEYS -- KEYROLL 04/12/2008
KEY 00 = D4 A3 5D EB 7B F3 69 59
KEY 01 = 27 77 A1 FC 8F 9D 34 76
TELEWEST KEYS -- KEYROLL 04/12/2008
KEY 00 = C0 F6 61 87 91 F9 67 57
KEY 01 = F0 83 35 E5 28 40 49 B2
PURE NTL KEYS (UK) -- KEYROLL 04/12/2008
KEY 00 = 3F B8 36 62 72 E5 E2 76
KEY 01 = 35 5E D6 40 6E AA 99 41
IRELAND NTL KEYS -- KEYROLL 18/06/2008
KEY 00 = 75 92 B1 CC 6F 23 20 F1
KEY 01 = F2 46 B1 59 04 61 77 71
Nov 28, 2008 | StarTech.com StarView SV211K 2-port KVM...
Cd code on radio kenwood
You need the remote control to clear the code, if you don't have one, then you may need to go to a KENWOOD agent, or purchase one for your use.
KENWOOD SECURITY CODE CLEAR procedure Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
The security is canceled and the set enters the TUNER mode!
Please rate ne FixYa for this solution. Good Luck :)
Jan 30, 2008 | Kenwood KDC-MP4028 CD Player
Computers & Internet Logo
80 people viewed this question
Top NCH Software Computers & Internet Experts
Dan Shibata
Dan Shibata
dhnguyen
dante
Are you a NCH Software Computer and Internet Expert? Answer questions, earn points and help others
