Question about Intel a38001-002 - 12v Dc 0.12a Cpu Heat Sink Amp; Fan Assy
I need an EAN # or UPC# fo this product
I just need the EAN # or UPC# if anyone knows what it is. Thanks for the help
I am looking for manufacturer information to find correct voltage info as well as a user's manual.
Guess first question is What is this item?
where did you buy it?
What is the "Brand Name"?
UPC/EAN listed is unknown/invalid. please verify
Nov 29, 2014 | Microwave Ovens
UPC code85948500222
Hi. I'm not sure if this will help you, but I found this website:
UPC Database Item Lookup
According to this website:
"Enter the all digits printed on the UPC bar code, including any numbers to the right or left of the bar code itself, even if they don't line up with the main row of numbers. This should be 13 digits for an EAN/UCC-13, 12 digits for a Type A UPC code, or 8 digits for a Type-E (zero-supressed) UPC code. Anything other than 8 or 12 digits is not a UPC code! (And just because it's 8 or 12 digits doesn't mean it is a UPC.) You must enter every digit here.
If you have a barcode scanner that outputs plain numbers, you should be able to use it to enter the UPC number here."
So, apparently you need more digits to complete the bar code #. But if you have the full barcode, you should be able to enter it on the website linked above, and find the image of the frames that you are looking for. I hope this helped. Thanks!
Oct 23, 2014 | Datalogic QuickScan QS6000 Plus Bar Code...
Honeywell
Scan "do not expand ean-8 to ean-13" in your programming guide.
Jan 18, 2013 | Honeywell Voyager 1200g Barcode Scanner...
Im trying to get my ls2208 scanner to read comic book barcodes its 13 plus the 5 digit extension can i get some help with this. im running windows vista 64bit not sure if that matters or not.
Just take a Print out this PDF file and Scan the Barcode
1st u need to scan the enable Interface Barcode then Scan Any barcode Length
Cheers
Hope its solves
Sep 05, 2011 | Symbol LS2208 Handheld
Enquiry
try to look at the bottom of the printer or if you have the printer box look on that its usually written on the down area
Mar 17, 2010 | Office Equipment & Supplies
UPC TO ISBN CONVERSION
Scan the Enable Bookland EAN barcode from the LS2208 Product Reference Guide. It is on Adobe page 166 of 342 of this guide: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=113980484&stateId=1%200%20113974371
Jul 08, 2009 | Symbol LS2208 Handheld
We need to convert UPC-A barcode number to EAN-13
Most scanners will convert UPCA to EAN13 as you scan if you have that setting checked. A 0 will be added in front of the UPCA to make it an EAN13. Nothing else changes. You can read about this stuff on Wikipedia.
Mar 24, 2009 | Symbol LS2208 Handheld
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
Intel a38001-002 - 12v Dc 0.12a Cpu Heat Sink Amp; Fan Assy Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
