Question about Casio DR-210HD Printing Calculator Adding Machine
Clean printer roller
Clean roller on adding machine
I have just replaced all the toner cartridges in my fax and it did a self clean. The machine was making these noises which sounded like the roller was getting stuck. It would then come up with a paper...
Open control panel on your personal computer where the printer is installed. Click the printer and faxes. Then right click on the icon of your printer and click properties. Then click the maintenance Click the Bottom Plate Cleaning. If the noise is still there after you clean the bottom Plate. Clean the Roller. And look inside your printer if there is something that blocking the roller.
Jun 24, 2011 | Brother IntelliFax-1860C Plain Paper...
I have the Xerox XD120f. Cannot pull paper from either drawer.
The rollers are either dirty , or most likely worn out and need to be replaced. They are not hard to replace, but humidity is not the problem, the condtion of the rollers is the problem. Try cleaning them with something like fantastic or formula 109, then clean again with alcohol.
They become slick and will not feed paper. You can google a business called The Parts Drop, they carry about everything for Xerox copiers.
Feb 15, 2010 | Xerox WorkCentre XD120F Laser Printer
When printing, a black stripe is printed on the back side of the printed pages (about 1/4'' wide, running from top to bottom). The ink strip bleeds through to obscure printed side. Any suggestions?
You need to have the exit rollers cleaned at a shop, and a mylar strip added to keep that from happening again. It's the ink from the cleaning station backing up thru the exit rollers.
Dec 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My Dell 942 printer will not pull the paper into the printer, unless the sheet is pushed in very far. The roller spins but does not grab the paper. Any thoughts? For one sheet I can print with the added...
If you use coated or matte paper at all, it will slowly put a coating on the pinch rollers, causing the problem you describe.
Get some isopropyl alcohol and lint free rags and clean the rollers thoroughly. That should solve the problem.
Oct 11, 2009 | Office Equipment & Supplies
Cannot read #'s on cash reg. tape
Many times its not easy to seat the inker. Also these machines have 2 rubber type wheels that will harden if the inker is not changed often enough. Also some people use thermal paper in these machines and that is not good either. if you are using thermal paper try using standard 21/4" adding machine paper. The type wheels may also be filled with glonck. you also may have bad inker. if the are crumbly they wont work
Sep 21, 2009 | Casio Parts Cash Register PC Desktop
I have cannon image runner 4570 that I cleaned
The transfer roller is cleaning use to a vacuum cleaner.The black lines is caused to dirty charge corona or charge roller.Clean the charge unit.
Aug 19, 2009 | Canon Office Equipment & Supplies
Printer won't take up the paper
I then cleaned the single big roller located further inside at the left at the back of the printer. Q-tips and Ixos spray. Thank you for your help.
Mar 27, 2009 | HP PSC 2355 All-In-One InkJet Printer
Cleaning carbon off inside rollers of HP 1020
Pry up at the ends. Don't get the roller wet.
Jan 30, 2009 | HP LaserJet 1020 Printer
Adding machine problems
how do I clean the printer roller on a Texas Instrument TI-5130 adding machine?
Apr 24, 2008 | Office Equipment & Supplies
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
Casio DR-210HD Printing Calculator Adding Machine Logo
50 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
