Question about Dacor PMOR30SS Microwave Oven
Broken door handle on the dacor
I have ordered the door handle but not clear on how to install the handle
  • Dacor Master
  • 9,098 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Sometimes you remove one handle screw, then gently rotate the handle to unlock it.
Of course this depends on your specific brand and model number.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If this does not answer it for you, please reply back with your brand and model number. Otherwise...
Posted on Jun 16, 2009
Dacor DCM 24. Everything, clock, fan, rotator, light all come on but oven and microwave don't heat?
On model DCM24, that's usually a defective bottom door switch, or its mount is loose, misaligned, or broken.
The service manual is here, and my help file on door switches is here.
For free DIY and other help and advice, feel free to contact me via my site.
Always include your FULL model number*, FCC ID number*, and detailed symptom information.
* from the tag in the cooking cavity or elsewhere on the oven (or send a clear photo of tag)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 24, 2017 | Dacor Microwave Ovens
PMOR30S door hinges are loose
The service manual for the PMOR30 is here.
The part list is here.
You can order Dacor parts by part number here.
Jan 08, 2013 | Dacor PMOR30 Microwave Oven
Can the handle be replace without removing the microwave from the wall?
Yes, you will need to separate the door panels.
The service manual is here and the parts list is here. You can order Dacor parts by part number from the Pros here.
Aug 03, 2011 | Dacor DMT2420SS Microwave Oven
Dacor DMT2420S Microwave has light and touch pad fully functional but when you push start, the clock counts down normally but no sound of the oven running nor does the turntable turn. Food does not heat....
Simple fix.
You need to replace the bottom door switch, or repair its loose or broken mount.
See this help file on door switches, and refer to the service manual here for disassembly help.
You can find part numbers here and order Dacor parts (by part number only) here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Aug 22, 2010 | Dacor DMT2420SS Microwave Oven
Fridigaire over the stove microwave. the handle is broken. We can order a new handle but don't know how to install it. Can you help? thanks, Linda C. e mail ...
You must take the door out by removing a screw then lifting the door off the hinge pin then the door must be laid on it's front and, completely
disassembled to replace the door handle.
Aug 13, 2010 | Frigidaire Microwave Ovens
Dacor microwave model DCM24s broken door latches
Many times restaurant supply houses can have what you are looking for in terms of hinges. However, when the hinges, seals, megatron tubes go....generally its time to go shopping for a new unit!
Nov 09, 2009 | Dacor DCM24SS Convection Microwave Oven
Need to replace handle on dacor microwave model: pmor30s. I have
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
In some cases, you then have to gently rotate the handle to unlock it.
Aug 02, 2009 | Dacor DMT2420SS Microwave Oven
Problems with our Dacor PMOR30SS 1100 Watts Microwave Oven
The part numbers for the door handles are 66181B for black oven and 66181R for arctic white oven.
You can order those by entering the part number here.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Dec 17, 2008 | Dacor PMOR30SS Microwave Oven
Dacor Microwave PCOR3OS will not heat/tunrtable not turning
This Dacor model is very similar to Sharp model R1874.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
You will need the
free Adobe Reader to view or print them.
This is probably a bad secondary interlock (lower door switch) or possibly its mount is loose or broken.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you only need a switch, you can order a universal type here for $5 postpaid.
Dec 16, 2008 | Dacor PCOR30SS Microwave Oven
Replacing a Dacor Microwave Over the Oven Door Handle for Model PMOR30
This Sharp-made Dacor model is equivalent to a Sharp R-1750-series and we have the complete service manual at our site:
http://www.microwavedisplay.com/r1750_r1751_r1752_r1754_sm.pdf
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 29, 2007 | Microwave Ovens
Dacor PMOR30SS Microwave Oven Logo
254 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
